Poll: Heads/Cam or Supercharger
full weight no weight reduction// forgot the driver mod
If I would have put a set of valvesprings in I could have hit 10's, my car was shifting only at 6 grand.
that's it!
new setup is still in the works but should be very soon.
that's it!
Show me a fullweight heads/cam on a drag radial that has gone 11.2 shifting at 6 grand. Oh that's right there aren't any..
I did a little research on you btw.
Here's what I found-this is good, lol..
your setup-98 Camaro Z28 Sport - Daily driver - Bolt-ons, MS3, 4k stall
your best time-60' 1.641 - 1/8 7.590 @ 91.63 - 1/4 11.921 @ 112.80
you barely cracked 11's,
and you're talking smack?
mike c. mike c. is offline
Trader Rating: (0)
well...i've been on stock ws6 tires and full weight running 11.21 122.27 best. i like the fect that i'm not on skinnies like all my friends and foe's. now it's comming down to 10's on the motor and was wondering if the skinnie little tires could gain me another 1 tenth or so in the 1/4th. the truth is all the people i've killed keep spraying more juce and i need all the help i can get.
i know hes shifting higher than 6000 but obvisously with a NA car you need a big cam to spin the motor high & good heads to make big power. i know he was running 17" in the front and i think et streets in the rear. still very impressive...to me anyways.
Heads/Cam with N20 going in. Cheaper. I like blowers, but don't have the $$ for major changes. A 100 shot on top of 413/383 should be fun.
I LOVE the sound of the H/C car on an M6, yet get my "boost" whenever I want to push the button
Lope gives me a hard on
Plenty of H/C LS1's around here running low-flat 10's on a 150 shot, low 11's on motor. Even got one LS1 H/C trapping 123 on motor and it's an M6 so the 126 MPH debate on boost is a moot point comparing apples to oranges with a power adder on a H/C LS1 such as Nitrous when they trap 132-134 in the dead heat of summer and worst time of year to race. You won't see many boost cars doing this kinda of thing in the heat without heat soaking the motor, but you can hot lap a H/C LS1 with spray whereas you'd end up parking a blower car after 1-2 runs.
Boost makes nice dyno #'s but that's about it. Evident with the Cobra. Best I've seen out of a 600+ Cobra on track is what a N/A HC LS1 is running........11.1 I haven't seen many earth shattering track times with blown LS1's to impress me to say a blower is better than a H/C power adder LS1. It's alot of money, you can pretty much have more fun for less money with an all motor LS1 with nitrous and less maintenance to worry about
the comparison here is h/c versus fi not h/c nitrous vs blowers.
nitrous is considered forced induction fyi.
tell those fast h/c cams to come up here in orlando, didn't know there were so many of them of them down in west palm. Are these full weight cars?
Oh fwiw I'd love to show you how heat soaked my blower car gets after just two runs. You can put your hand on my aftercooler and it'll be nice n cool to the touch. Please know what you're talking about.
Oh yea all of the fastest and quicketst ls1's are guess what Forced Induction not nitrous and definitely not heads/cam.
you ain't fast without your bottle baby. I like my power all the time.
I guess you can say it isn't fast without the bottle, if you consider low 11's to be slow.
I'll take a low-mid 11 second street car that turns into low 10's at the flip of a switch and comes with badass lope anyday. Well, eventually........
from what ive seen on here, and maybe im wrong but this is just what i see....FI power vs NA power...NA wins handsdown. the only problem is you can only make so much with NA but with FI you can make WAY more power. id rather have 460rwhp NA than 460 FI anyday. the problem is, 460 NA is close to being maxed out, unless you get unstreeable (IMO) 460 for FI is just the begining. if I had to stay with the stock bottom end...H/C would be my choice no doubt. im just not a nitrous guy. i love romping on the gas way to much. id go through 2 bottles per night and that would get too expensive.
Secondly, say you have a 500rwhp blower car vs a 500rwhp 408 car, both behind 6 speeds, lined up on the street.......assuming equal drivers, tires, traction (or lack thereof) etc, which would pull of the better "street" 1/4 mi run?
This car, 347cid, '01 z06 cam, stock pushrods/rockers, stock valves (98 heads still) with '02 z06 springs, mild CNC port, stock connecting rods w/arp bolts, off the shelf replacement forged pistons, LS6 intake, power steering, power brakes - idles/drives like a stock car. Shift at 6600rpm. 9.90 @ 136 on a 1700' DA day @ 3300lbs. Also made 11 passes at NvsS with the car in 95+ degree weather and the only problem I had was the Y-pipe blew off the exhaust every 3 passes - still managed to win the bracket race though. Took the car home after NvsS, washed it, swapped wheels and tires, bolted the hooker muffler on and put 150 miles on it just cruising it around the next day with the T-tops off - cant beat that IMO.
Two extreme examples but I have had other more mild head/cam cars and blower LS1 cars also and its really hard to beat an FI car for a serious street/strip car IMO. Although for most a 425-450rhp head cam + nitrous is a better bet and way more forgiving for most then fooling with a blower/turbo but neither is cheap. I dont think either one is 'better' or cheaper but you can slowly work your way up with a cam, then heads, then intake, then headers etc, FI takes a big chunk of cash up front.. My advice, build one of each
nevermind i got it
https://ls1tech.com/forums/forced-induction/344874-414-7500rpm-solid-roller-vs-d1sc-stock-motor-dyno.html
I could have ran 9.80s or so in good weather with a little playing with the n/a car I'm sure To be honest it was very high maintainance and aside from the way it sounded at idle it was very little fun, especially around here.
I like a big cammed NA car as much as the rest but this car is fancy subdivision friendly. It doesnt set off my neighbors car alarm or my garage smoke alarms when I start it, or make the neighborhood children (and old folks) cry. Even gets fairly decent gas mileage
he he he... That's maturity talking there boys!
I love a big cam sound but in the real world driveablitly of daily driver's it just wont do for me either. Unlike a lot of people.. put a FI set up on their stock LS1's.. and they pretty much run the same times at the track cuz they can't hook haha.. and if they throw slicks on they will blow their rear, driveshaft, or trans.. AND they blew all of their money and have no money for a rearend or trans anyways! So for a long time they are stuck with a FI that can't hook for **** and is definately killing the **** out of the trans and rear..
Smarter to start off with H&C and work your way towards forced induction later on down the road!
By buddy on a 01 z06 heads/cam and i put about 3 1/2 cars on him from a first gear roll...then he added a fast intake/TB and we were dead even...I Had a little stonger 1st gear then dead even....
Although I have a 01 ws6 procharged at 6-8lbs slips w/ 6 rib belt and full exhaust...no weight reductions on either car...
