Turbo Differences
Old Aug 26, 2005 | 04:31 AM
Kaneman's Avatar
Default Turbo Differences
What is the difference between the ptrim, qtrim and GTS? Does one make allot more power then the other?
Kane
Old Aug 26, 2005 | 11:17 AM
gnx7's Avatar
Ptrim refers to an internal style wastegate (WG) in the turbine housing, Q trim is an external gate style turbine housing with no provisions for a WG and requires you to put one on the headers/crossover to control boost, and the new GTS style housings I believe work with a larger exhaust wheel and newest design in turbine housings with the need for an external WG like the Qtrim.
Ptrim produces the least amount of power; however can be easier to package (as it requires the least amount of room and when a properly sized WG puck is installed it can control 750hp+ without creep). Ptrim is maybe 30hp or so less compared to a Q trim. GTS is supposedly one of the top dogs out when putting together the turbo hot side.
Old Aug 26, 2005 | 11:23 AM
69firebird's Avatar
go to www.forcedinductions.com
they have a very good explination of all that.
ed
Old Aug 26, 2005 | 11:27 AM
turbocuda's Avatar
gnx7......what you say!.....P trim is just the name of the turbine wheel, so is the q trim...actually not trim at all, just O, P, Q and so forth. They get larger and flow more exhaust the higher the letter goes.
Old Aug 26, 2005 | 01:25 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Yes the letters represent size. Higher is better
Old Aug 26, 2005 | 03:12 PM
Zombie's Avatar
Wrong, P-trim refers to the wheel and has absolutely nothing to do with what kind of waste gate is used. None of the wheels sizes determine whether or not wastegate is internal.
Old Aug 26, 2005 | 05:13 PM
gnx7's Avatar
I thought it referred to the WG setup as well. Oh well.
Here is a link to a Q trim T-70. Looks like it has the capability to have a WG in the housing as shown in the first picture on the left side: http://www.gnttype.org/techarea/pictureguides/turboguide/T70.html
Old Aug 27, 2005 | 08:40 AM
Shane_G's Avatar
Did you get my PM about the turbos?
