Is 600rwhp realistic for my setup?
-Forged Wiseco Pistons
-Forged Eagle Rods
-Stock Crank
-Stock Ported Heads
-Comp Cam 232 236 dur /.595 .600 lift on a 114lsa ( I know turbos like reverse split ,higher on intake than exhaust =(
-Hardened pushrods
-comp 918's
-ls6 intake
-150hp TNT
-Walboro In Tank Fuel Pump
-ARE Ported Oil Pump
-Some Suspension goodies...etc
I want to go single TURBO setup and I have been tryin to read up as much as possible about turbos and brands...I want to have 600 rwhp for a street car and want to keep my A/C if anyway possible...and on PUMP GAS 93 octane....is this a realistic goal without tearing down my motor?? or will I have to make a lot of changes in order to accomplish this
Things Ill need (And I need some help on this pls)
-Injectors (60lbs??)
-Added in line Fuel Pump (what Kind?)
What Else??
Thanks Guys...I have a feeling this is going to be a money pit..but that sound and power just gets to me!!
If you goal is 600 adn you use methanol you can use 42# injectors with your intank and be fine. If you dont wanna use meth then you have to get 60#er's and prolly a dual intank setup. You can prolly get away with keeping the rest of the fuel system stock, IE rails lines FPR. But doing them is a good idea as you will get bored with 600 after a little while. Especially since you have a forged engine that can handle ALOT more then 600.
I would recommend gettin meth wiht even the stock CR pistons. It is a big saftey thing.
As far as a turbo kit goes i think that most of the kits available make it so that the AC is still usable. I know my Phamspeed kit does. And so does the kit that they currently sell through Ground Zero Motorsports. GL man
John
normal split pattern cams are preferred for superchargers, reverse split are good for turbos...
I think stock 10.1:1 compression + 600rwhp is doable, with 60 lb injectors. As long as the tune is not crazy and you have some sort of intercooler.
-60lb injectors
-inline fuel pump (added with mine)
-Turbo kit (looking at the Pham Speed T70 w/ FMIC)
There seems to be something that is always left out of 'kits' that seem to be a couple bills..How much boost you think it would take to pull this off?
-60lb injectors
