Turbo Headers? Cost and who
Brett
Make sure you use good materials. I imagine if they are not off the shelf, they will be big money! Trending Topics
Make sure you use good materials. I imagine if they are not off the shelf, they will be big money!How long did it take you to do those? Did you also have to machine the flat stock or can you buy that stuff setup for the LS1 heads? Why did you make them slip fit, is there an advantage to doing them that way?
Those are great looking pieces but you have the added advantage of more space under the hood of that chevelle vs. an LS1 F-body.
Ok, now, explain slip fit to me.
Since conventional slip headers would most likely leak under turbo backpressure ( north of 50 psi on the higher boost cars) People build a second slip to aid in sealing.
Burns does an excellent Job at them, but expect to pay a premium. http://burnsstainless.com/MergeColle...ollectors.html
You have me thinking now, I have a Miller tig and plenty of 321 wire!
