turbo and nitrous
Old Sep 2, 2005 | 04:00 PM
klw1313's Avatar
Default turbo and nitrous
if you had the motor built to handle high amounts of boost, but were only running around 13-15 PSI would it handle say a 150 shot at the same time?
anybody else running nitrous and forced induction? i know you would have to tune it to handle this.
what other precautions might i need to take?
Old Sep 2, 2005 | 04:04 PM
Reject's Avatar
there are a bunch of ppl runnin nitrous to get the turbo to spool up faster, but if you wanting to run higher boost, ppl would recomend the alky/water injection.....correct me if i got the fuel wrong (forget sometimes!)
Old Sep 2, 2005 | 04:06 PM
klw1313's Avatar
im saying run 13 PSI and a 150 shot. im not going to up my boost, well i cant unless i get a new turbo.
Old Sep 3, 2005 | 02:12 PM
aggiez28's Avatar
it can work
brook
Old Sep 3, 2005 | 03:00 PM
eviltwins's Avatar
If you're maxing out the turbo at 13 psi you'll stand a good chance of damaging it if you hit it with a 150 HP hit of nitrous. That's a ton of extra exhaust flow, and will overspin the turbo easily.
My advice? Go get a properly sized turbo and ditch the bottle.
Old Sep 3, 2005 | 03:40 PM
cablebandit's Avatar
i installed the hardware side of a dry kit today to get my car to get off the line....i'll hit it with about a 75rwhp shot for about 1 second and see what happens
Old Sep 3, 2005 | 04:54 PM
klw1313's Avatar
let me know how that works
Old Sep 3, 2005 | 05:58 PM
first opportunity will be Sept 25th and of course i'll post the results
