Guys running GM MLS ENTER HERE
Old Sep 12, 2005 | 11:40 PM
ABeasst's Avatar
Default Guys running GM MLS ENTER HERE
I asked this in here because most of you guys run this gasket so.....I have searched and cant figure out which part # I need. I need the GM MLS gasket for a 3.905" bore. Also how thick is this gasket?
thanks
adam
Old Sep 13, 2005 | 05:40 AM
smokinHawk's Avatar
dont think they make it with the 3.905 bore (GM anyways).
most use the over sized 4.0" bore.
you can get a cometic 3.905 bore, they also have several thicknesses to choose from.
Old Sep 13, 2005 | 08:28 AM
ddnspider's Avatar
actually thats not correct smokin they do.....heres an Email from Eric at HPE about the gaskets for my 383 w/ 6.0 ltr heads."We would use the GM MLS like on yours I’d do the 9227 6.0 gaskets that go with your heads."my bore is a 3.905 as well
Old Sep 13, 2005 | 09:31 AM
ABeasst's Avatar
so whats the P/N?
Old Sep 13, 2005 | 09:32 AM
smokinHawk's Avatar
do you have the part number then?
Old Sep 13, 2005 | 09:40 AM
ddnspider's Avatar
why not just call up your local dealer and tell them that
Old Sep 13, 2005 | 09:43 AM
ddnspider's Avatar
or even better call up Eric @ HPE and ask him yourself and they were CHEAP to boot
Old Sep 13, 2005 | 10:11 AM
PurEvl's Avatar
i ran this gasket with a 3.905 bore
Old Sep 13, 2005 | 11:26 AM
ABeasst's Avatar
I have found these 2 part numbers.....12589226......12498544
Old Sep 13, 2005 | 11:46 AM
smokinHawk's Avatar
im running the 4.0 bore ones with the 6.0 heads though (from cometic due to a non standard thickness.
Old Sep 13, 2005 | 11:48 AM
ABeasst's Avatar
Well I just want to make sure I can run 12498544 w/ my 5.7L heads and 3.905 bore
