My STS track times
Old Sep 25, 2005 | 06:55 AM
  #61
JEB99TA's Avatar
But, you don't have enough turbo boost to tell me my IP address behind my CISCO 2500 router ... what's my NAT IP????
Old Sep 27, 2005 | 08:10 AM
  #62
OUTLAWZ RACING's Avatar
longonb4u i think it may work good on a regular set up shorter distance for air to travel i hink that cam would be good if it was like 224/220 the higher intake will cause it spool faster and be more efficent through the rpm band i wish i would have went bigger in the 427
Old Sep 27, 2005 | 11:14 AM
  #63
longrange4u's Avatar
I am still trying to figure what I will do about my engine... Simply pull the 347 and harden it or if I will go with a stroke, or even a 6.0L Iron block. I am trying to figure out what is the best bang for the buck.... Dollars spent vs HP Return
Old Sep 27, 2005 | 11:51 AM
  #64
trtturbo's Avatar
Jarred, we will have the results of the 226/220 .570 .564 115 cam in a day or so. That should give you a good idea if you want to go a different direction with the cam. This is stock c.i. with forged rods and pistons (flat tops), stock #317 heads with 918's, stock exhaust through an A4 with a small stall
Old Sep 27, 2005 | 05:50 PM
  #65
I dont know... I dont have any issues with the GT2-3 Cam and I would like to see how it does with the larger turbo
Old Sep 27, 2005 | 08:36 PM
  #66
Thats One Thing About Power Its So Weird To Come By I Think That Cam With A Lot More Boost Will Net You Some Nasty Tourq But Hp Will Be A Little Low But Who Cares Track Times Tell The Real Story I Cant Wait To See How You Do
Old Sep 27, 2005 | 08:44 PM
  #67
BILLY !!! HOW R U ? MAN THE 427 IS COMING ALONG GOOD MINOR SET BACKS BUT I HOPE FRIDAY OR SATURDAY IT WILL BE DONE NEED YOU TO LOOK AT THE KIT FOR ME BEFOR I PUT IT ON THE DYNO AND HOOK ME UP WITH 67 OR 76 TRIM TURBO ALSO SOME INTER COOLER UPGRADES AND RELOCATE THE MAF AND BOV AND SOME BIGGER INJECTORS I HAVE THE FUEL PUMP ON HAND AND SOME OTHER THINGS OH MY BOOST CONTROLLER E. MAIL ME THE PRICE FOR THE ELECTRONIC BOOST CONTROLLER IF EVERYTHING GO RIGHT I WILL SEE U SATURDAY IF YOU HAVE TIME WITH MONEY IN HAND (NO MORE UPS) E.MAIL ME AT TANK2_99@HOTMAIL.COM AND WHERE ARE MY DECALS??????
Old Sep 27, 2005 | 10:08 PM
  #68
Yea you are right... Does anyone know the direct effect of HP vs TQ? I am the only one I have seen with numbers that are this differend (431/497) any estimates on my 1/4?
Old Sep 28, 2005 | 07:20 AM
  #69
RealQuick's Avatar
my head hurts...punctuation bro!
Old Sep 28, 2005 | 07:38 AM
  #70
My bad beer had the best of me. I drive better than I type wanna race for pinks will travel? JK!!!
Old Sep 28, 2005 | 07:48 AM
  #71
Tourq is what get you going. I want more TQ than HP because the more you have the faster you are from a dead stop. I think its that cam because of the duration on the exhaust side and the heads. Those heads flow better than my 241 and my not match well with that cam as far as valves sizes I am by far no pro but I tried to match my cam with my heads after the small port polish work Comp was real helpful but that cam was for the 346 and i put it in the 427 so i dont know how it will do my number for the 346 where on a zo6 clutch fidanza fly wheel and stok 10 bolt with 373 i dont know as for 1/4 maby high to mid 11 maby high 10
