SDCE and Shims
Old Sep 20, 2005 | 11:07 PM
Ed Blown Vert's Avatar
Default SDCE and Shims
Just wondering what everyone used to get the blower aligned. Trying to figure out what to start with.
Old Sep 20, 2005 | 11:34 PM
bomax's Avatar
I think I used two shims
Old Sep 20, 2005 | 11:36 PM
kp's Avatar
kp
2 here too
Old Sep 20, 2005 | 11:38 PM
I am assuming the .125” shims
Old Sep 20, 2005 | 11:55 PM
Brent@LPE's Avatar
man... isnt that a mess,behind the pulley?the stands?
Old Sep 21, 2005 | 12:08 AM
NA$TY-TA's Avatar
i used two or three... dont rememeber its been a while....
Old Sep 21, 2005 | 01:38 AM
BOONE's Avatar
2 .125 shims and 1 machine grade washer. For alignment you can make the tool they suggest or improvise. I used a compass I had for carpentry work, the part where the pencil goes was square and machined so I put it on the bracket and adjusted the pointer to the center of the protruding ridge on the blower pulley. Then just turned it 180 to the crank pully to see the corresponding ridge.
Old Sep 21, 2005 | 01:41 AM
BOONE's Avatar
Its really only 1/4" or so give or take, and its reliable, and no tension adjustment ever.
Old Sep 21, 2005 | 08:06 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i used 3 on each stand
Old Sep 21, 2005 | 12:45 PM
Thanks, I will start with two .125 shims
Old Sep 25, 2005 | 05:48 PM
Well lost my first belt.
SDCE supplied a shim that went under the blower pulley. Do I need to run the ATI shim and the SDCE shim? Or just the SDCE shim??
Old Sep 25, 2005 | 08:36 PM
Caveman's Avatar
10 & 11 Second Club
Not to be a jackass but wow your just now getting your car finished? Its been at least 1 1/2 years since your probs started with Jay with the heads. That makes me feel better about my Vortech car still not being finished.
Old Sep 25, 2005 | 09:32 PM
I got the heads a few months back. But just put in a 383.
Old Sep 26, 2005 | 07:43 AM
Chas1's Avatar
How long did it take to get your bracket back from SDCE?
Old Sep 26, 2005 | 11:02 AM
It took a couple of weeks. They usually wait till they have alot before making them. And that is usually once a month.
Old Sep 26, 2005 | 11:07 AM
ed how many spacers did you end up using
Old Sep 26, 2005 | 12:23 PM
I started with (2) .125" and a .062"
So now I am trying (3) .125"
