Bigger piping on a STS
If you meant the exhaust system as a whole, then imo, yes, you would want larger headers, and a larger exhaust system.
Think of it this way, its more air trying to get out, so it needs more piping if you are referencing a 427 vs. the normal LS1.
Tim did I ever tell you I hate you. You suck.
So you are getting a 427 bastard
. How much did that run you? Oh and tell the rest of the Outlawz I said what's up. How's the paint job on my car coming???? Trending Topics
60lb fuel injectors
255lph or higher fuel pump
intercooler
tr6 ngk plugs
boost controller
blow off valve i know you have an auto but it will save your turbo if you come out off the throttel fast
now for the add ons
snow performance meth kit
stall converter 3000+ to help build boost off the line
cam a zo6 cam will work fine but if you want a bigger one then call speed inc
harden push rods and 918 comp springs
oh heads get 317 there 6.0 heads low compression they are the same as the zo6 but with bigger bowls to help with the compression i price some through gm for540 a pice
i got with tammy she is cool
and if you want call scoggin dicky for a short block
take your time and shop and save money i will do my part and let you kno w what i find
and where i got my engine do is my secret it was in atlanta you know my brother has a 650hp 300zx one ricer i will respect but i will hit u up on an e.mail to further the details you know a 1800 dollar bore job and balance rotating assembly for free cant let to many people know about it a 427 may be a little over board for you if you dont want a big gas guzzler me i dont care pay to play a 402 will net you 600+ so holla
keep your head low and clean your weapon damit!!!!!!
60lb fuel injectors
intercooler
tr6 ngk plugs
boost controller
now for the add ons
