Operation: FIRE HOSE is a GO!!!!
Old Feb 13, 2002 | 06:02 PM
y2khawk's Avatar
Default Operation: FIRE HOSE is a GO!!!!
Well
I've begun the attack on my new fuel system.
Got alot of pieces, and have made progress on the tank.
Car goes up in the air this weekend for test fit of the tank. Will pick fittings for the back half of the system then. Then it's time to pick line locations, and engine compartment routing <img src="gr_grin.gif" border="0">
This should be fun
http://harlan.sketchy.net/fuelsystem/
As it's currently layed out, i should be able to support about 1100 FWHP at 20 psi on 96 lb/hr injectors. Wish me luck
<img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
Old Feb 13, 2002 | 08:16 PM
2001-WS6's Avatar
Default Re: Operation: FIRE HOSE is a GO!!!!
You going to have to be careful... at the rate you're going, you will need to have a pressurized cabin soon. <img src="gr_grin.gif" border="0">
Houston, we are condition go for launch in 3... 2... 1... <img src="gr_grin.gif" border="0">
Rick
Old Feb 13, 2002 | 09:31 PM
blackhawk2000's Avatar
[quote]Originally posted by y2khawk:
<strong>As it's currently layed out, i should be able to support about 1100 FWHP at 20 psi on 96 lb/hr injectors.</strong><hr></blockquote>
Yeah but is it going to be enough? <img src="gr_images/icons/wink.gif" border="0">
Old Feb 14, 2002 | 08:42 AM
Edster's Avatar
Are you selling your old fuel system?
20psi? Why so low of a pressure?
Old Feb 14, 2002 | 09:33 AM
y2khawk's Avatar
[quote]Originally posted by Edster:
<strong>Are you selling your old fuel system?
20psi? Why so low of a pressure?</strong><hr></blockquote>
That's 20 psi of boost <img src="gr_grin.gif" border="0">
45 psi base fuel pressure.
Yes, i'll be selling off the old system. Not sure when yet.
Old Feb 14, 2002 | 01:22 PM
Vortech396's Avatar
Did you build that tank yourself or is that the one from www.chargedair.com ?
looks great <img src="gr_grin.gif" border="0">
good luck
John
Old Feb 14, 2002 | 01:50 PM
y2khawk's Avatar
Nope, all me <img src="gr_images/icons/cool.gif" border="0">
That's a stock steel tank from a '98. I used a Comp. Eng. sump kit.
I stumbled across another sump that i may have liked better. Jegs has one slightly different. But i think this will work just fine.
Old Feb 14, 2002 | 02:37 PM
Rock's Avatar
That is killer man. I've been contemplating building a serious fuel system but really don't have the need. Jest looks like something funn to engineer. Maybe next year.
It's nice to have parts that you can grow into eh?
What's up with those fuel rails? Those aren't the 5.0L ones are they?
Happy plumbing my freind.
Old Feb 14, 2002 | 02:42 PM
IndyZ28's Avatar
Yes they are for a 5.0. They are nice!
Old Feb 14, 2002 | 02:57 PM
NoOne's Avatar
Harlan,
Are you worried at all about the noise or have you decided power over ears <img src="gr_grin.gif" border="0">
That was the pump Nick was putting on the Camaro until I found out it was external, thats where the dual tank idea came up.
Good luck, I can't wait to see it run.
your only going 9:1, not lower? Get it down around 7.5:1 and you might make 800rwhp on pump gas!
[ February 14, 2002: Message edited by: NoOne ]</p>
Old Feb 14, 2002 | 03:24 PM
y2khawk's Avatar
Yep
5.0 rails. The center to center bore spacing is the same, and the injector angle relative to the rail is the same. However, the LS1 injector angle bank to bank is reversed. So the mounting tabs are backwards. I can't use the supplied ones anyway, so i didn't care. I got them more for the use of o-ring AN instead of NPT for the lines into the rails. I hate NPT on fuel lines. I plan to weld in the fittings for the sump once i test fit to determine if i need straigh ot angled.
As far as the noise goes Eric, we'll see. I've got the pump controller to run it at low speed until i need the fuel. Part to extend the life of the pump, second to keep it quite. Yes, a relative term <img src="gr_stretch.gif" border="0">
I'm not too concerned about it. I'll isolate it the best i can from the car, and deal w/ the whine. I personally think a mellow exhaust tone, and a LOUD *** PUMP are more intimidating <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
Old Feb 14, 2002 | 04:05 PM
XLR8NSS's Avatar
Adkoonerstrator
I've got a A1000 and it doesn't whine. It GROWLS GGRRRRRRRRR... Too loud for me. Thank god it doesn't run all the time. <img src="gr_grin.gif" border="0">
Harlan, what the hell is sticking out of the ends of that pump in the one picture. <img src="gr_eek2.gif" border="0">
Johnnie
Old Feb 14, 2002 | 05:33 PM
y2khawk's Avatar
hehehehe
those are the fuel filters <img src="gr_grin.gif" border="0">
Even those are HUGE <img src="gr_eek2.gif" border="0">
Old Feb 14, 2002 | 06:08 PM
cablebandit's Avatar
LOL.....looks awesome Harlan. I was just thinking...we are gonna pay for that fuel setup with all the damn 2 steps we will buy! Life is good in LS1 land!
Old Feb 14, 2002 | 08:38 PM
smokinHawk's Avatar
Hurry up and get that fuel system in there so i can get your old injectors.
800rwhp your gonna kill yourself <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
you make me sick <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
youll be running nines soon.
if i had that kind of green
your wanting the king of FI crown arnt you! <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old Feb 15, 2002 | 11:59 AM
turbolx's Avatar
Good.... now hurry your *** up so we can get back on the dyno and have a little more fun this year, Harlan. <img src="gr_images/icons/wink.gif" border="0">
Old Feb 15, 2002 | 01:07 PM
cASe SenSiTive's Avatar
Looking simply bad-*** Matt. <img src="gr_grin.gif" border="0">
Looks like I'm gonna need a lot more nawwwwwws to keep up with you now. <img src="gr_images/icons/wink.gif" border="0"> Can you say "direct-port fogger"? <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
Old Feb 15, 2002 | 08:41 PM
Brady's Avatar
LS1Tech Sponsor
Man that looks great! What do you like more about the JEG'S sump? I need to order one soon.
Not being Mr. Smarty-Pants or nuthin, but are you sure that's going to be enough fuel pump? I spent a lot of time talking with Aeromotive at the PRI show and if I remember correctly he said that pump would be borderline.. Maybe the difference is injectors though, I'm only running 85# injectors.. Oh well, too many <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" /> to remember now.. <img src="gr_stretch.gif" border="0">
Looks great! Best o'luck <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
...Brady
www.wheelhop.com
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Feb 16, 2002 | 08:29 PM
y2khawk's Avatar
Brady
I found the Jeg's sump after i went with the CE one. The Jeg's is angled on the sides, but it's a smaller volume. The CE it pretty good, and seems to fit well in the car.
The pump is big enough. I spoke at length w/ the aeromotive tech guy. This is their newer pump. You may have been discussing the eliminator pump, the bigger of the red pumps.
We did the back of the envelope calc's over the phone, w/ 96 lb/hr injectors, base pressure of 45 psi, and assuming 20 psi of boost to get there, the system will support 1100hp at the motor.
Should be ok i think <img src="gr_stretch.gif" border="0">
Old Feb 19, 2002 | 06:00 AM
strife's Avatar
so is the sumped tank in lieu a surge tank something like this
[ February 19, 2002: Message edited by: strife ]</p>
