Oil Blow By
During a 30 minute session I'm probably under boost 60% of the time. I guess the constant pressure build up is too much and the oil starts blowing out.
I hope someone has some ideas..
Further inspection showed that there was considerable oil in the inlet hat and had actually made it all the way to the intercoolers. I talked to Jason at GWP and we agree that it is oil blow by from the crankcase pressure.
I've already installed a check valve on the PCV line. I've had that since the beginning. I double checked yesterday and it does appear that I've got the flow direction right.
Any suggestions as to how I can deal with this issue. Jason recommended an EVAC setup but I'm cheap and would like to try something else first.
Thanks.
__________________
Gary
'99 Trans Am
510.8 hp/477.7 torque
www.gdjenkins.com/mods.html
He did call ATI, and they know of the problem, but do not have a fix for it.
What is a evac pump?
John
I have blocked/disabled the PCV valve and then the oil get's blown'pressurized out the crankcase breathers and 'burns as it drips onto the exhaust manifolds. I ran a total of 3 breathers for a while. Right now, I freed up the PCV valve and have just an oil breather cap. May try the catch-can soon?
Dan
Wouldn't it be not the vacuum created during boost, but the positive pressure created when the Throttle Body blade closes after a WOT run. This positive pressure forces the weak stock PCV valve open. This pressure blows into the valve cover and exits out the fresh air valvecover nub, spewing out the pressure and oil with it.
The PCV check valve prevents this positive pressure 'blow off' from entering the PCV system. A good blow off valve should help too, eh?
I check mine again just a week or so ago, because of the posts about it, and that hose going to the inlet hat is clean and dry.
Jason seemed dubious about the need for it. I guess we both felt if I didn't have a problem, why dic with it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>I was told today that one of the Cadillac engines has an electrical evac pump on it. Anyone know anything about that?
Gary.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I posed that question to my brother, who knows more about Cadillac engines then anyone I know, (pasted from his email):
"The big inch cads (68-76) never had that that I know of. I mean, they had
some weird stuff, like electric air compressors to drive air shocks,
hydroboost brake boosters that are driven by the power steering, and even
multipoint fuel injection ('76 only), and climate control computers, but I
never heard of a vacuum pump on the ones I mess with.
My guess is that if it is for blowby, it would have been for the disastrous
aluminum 4.1 front drive V-8 in the '80's. From what I have seen in my
Electrical component locator (1988 Mitchell), there is an electric vacuum
pump located inside the left front fender, at the front of the vehicle on
1988 Deville's and or Fleetwoods, it is probably located in other years of
those models, also. However, the Allante/Cimmaron/Fleetwood Broughams/El
Dorados/Sevilles do not show it.
There is no computer trouble code for the vacuum pump in the Deville and
Fleetwood diagnostic section, so if you want to find in-depth information,
you may need to do some digging."
Tim
<strong>I have the check valve installed in the PCV line. So at least in my instance the blow by is not from that source.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not to be thick, but your arrow on the check valve points towards the Throttle Body, right?
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TaxMan:
<strong>I have the check valve installed in the PCV line. So at least in my instance the blow by is not from that source.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not to be thick, but your arrow on the check valve points towards the Throttle Body, right?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually it was the first thing I checked. I even took it off and blew through the valve just to make sure I had it right. So, yes. It is installed the correct way.
Or you could try adding another check valve there, but I'm not sure how much suction, if any is created off that nub.. after that a breather filter.
I have thought about adding a catch can with a breather filter. However, I thought the purpose of having the hose run from the valve cover to the inlet hat on the ATI was to 'suck' any pressure buildup in the valve cover out.
If I add a catch can, the 'sucking' won't happen. With my limited knowledge I can't decide if that would be bad for my application.
Any thoughts??
The passenger side has a 2nd nub at the front of the valvecover. This is used to bring in fresh air while the other air is sucked out. Now if you pressurize the crankcase under boost it builds up pressure and the fresh air nub is the only place it can release pressure and this is where the oil shoots out.
The only issue on the fresh air nub is whether it sucks in MAF metered air or not. The normal ATI system just routes it up to your air filter area and it isn't metered anyhow. So a breather on the FRESH AIR nub is ok and your PCV system remains in place with a check valve. The fresh air nub could have a catch can or maybe another check valve installed in addition to the breather, otherwise you'll just shoot oil out the breather instead of into your air filter and intercoolers.
