LS1 Motorsports Single Turbo - 534rwhp / 687rwtq !
Old 04-22-2002, 10:26 AM
CHRISPY's Avatar
Default Re: LS1 Motorsports Single Turbo - 534rwhp / 687rwtq !
GREAT numbers!!
I wonder what your fuel pump, line and injector requirement would be for a 9.5:1 HCI car?
That turbo is gravity fed right? What were the ambient temps for the testing? are you running a front mount intercooler?
Imagine this kit with:
230/230 XE-R based cam
Forged 9.5:1 pistons
Good set of ported heads with 2.02 1.60 valves
and a killer fuel setup and injector.
Boggles the mind haha <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Great work guys, very impressive <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
Old 04-22-2002, 11:40 PM
AlienDroid's Avatar
So what area of price range do you think this kit and install will be. 4-6,000, 6-10,000, 10-15,000 or 15,000+
I'd like to know because if it's in the price range I feel is right, I'll save up for the kit, already have $6,000 but I'm tempted to buy something for my car and I've also been looking at motorcycles.
Old 04-23-2002, 12:07 AM
Shorty Director
VINCE's Avatar
230/230 XE-R does not sound like a blower cam..
Old 04-23-2002, 12:46 AM
SSU Moderator
RyanJ's Avatar
and a single turbo kit does not sound like a blower... <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> sorry, had to get ya on that one. i knew what you meant though. just because the cam isnt intake biased (for a turbo) or exhaust biased (for a blower) doesnt mean it wont give a viable increase in power comparitively to the same set up with the stock cam. it may a tad less that a cam of the same size with the proper config (intake bias in this situation), but it will increase overall output.
Old 04-23-2002, 12:51 AM
Shorty Director
VINCE's Avatar
How much of a difference in horsepower? 10, 20, and possibly 30rwhp? I have always wondered this..
Old 04-23-2002, 12:58 AM
SSU Moderator
RyanJ's Avatar
i would guess that at that level, between a 234/230 and a 230/230 you'd be giving up 10-15 in certain areas (slightly past peak according to Patrick's dyno) by going with the single duration. but all that could be wrong...im not an FI masta. basically an intake biased cam is making sure that the cylinder is ALWAYS full. that equals power in some way or another (the higher the cylinder pressure the more power you get...as in N2O and FI).
Old 04-23-2002, 03:31 AM
Shorty Director
VINCE's Avatar
I was just wondering.. My next cam is going to be a 226/226 XE-R cam.. and I was told that this is not a good blower cam..
Old 04-23-2002, 07:57 AM
CHRISPY's Avatar
Turbos and blowers have different requirements as to cam specs. Remember Turbos are exhaust driven and generally like less exhaust duration than a blower cam.
Vince, that cam will perform fine on a blower car. I would consider a XE-R 226/230 cam though depending on P to V clearance but the 226XE-R will be fine as long as you maintain 114LSA.
Cheers,
Chris
Old 04-23-2002, 08:03 AM
cablebandit's Avatar
Good numbers Rob!! While my car is down, I am trying to address some of the ineffeciencies of my turbotech kit. Can you give me an idea of spool up time? It seems I would see 8 psi right around 3300 rpms with the t-76. I may go to a smaller exhaust housing to get that down some. What size downpipe did you end up with and what size crossover?
Old 04-23-2002, 09:48 AM
AlienDroid's Avatar
Another Question for ls1motorsports. How much weight did the Agostino ls1 iron block weigh compared to the stock motor? How did you get the car up to 38xxlbs? The car itself must weigh around 3700lbs. That's almost 300lbs more then stock.
<small>[ April 23, 2002, 09:50 AM: Message edited by: AlienDroid ]</small>
Old 04-23-2002, 10:33 AM
SS00Blue's Avatar
Wahoo! I finally decided what I wanted to do...
Stage II LS1 Motorsports single turbo kit (Order Number <low 20ish>!!!
SC
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
<small>[ April 23, 2002, 10:36 AM: Message edited by: SS00Blue ]</small>
Old 04-23-2002, 01:58 PM
  #32
Shorty Director
VINCE's Avatar
Chris I am going to run NA for a year and save up for the blower and stuff.. I chose the lsa of 112 for now. I will change cams for my new application.. I am going to go with whatever the vendor doing my setup suggests..
Old 05-09-2002, 03:32 PM
  #33
Silver TT's Avatar
Rob - Any further info on the kit?
I am currently thinking about buying a forum member's 422 and was thinking about your kit after I get "bored" of the 422 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The engine is currently getting freshened up so I could potentially influence which pistons, cam, etc. are put back in the block.
If I wanted to get in the neighborhood of 600 rwhp and 650 rwtq but stay 100% streetable and reliable, will I need the 7psi or 9psi kit?
Would an ARE 422 with all forged internals hanldle the 7 or 9 psi without dropping the compression? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks,
Dan
Old 05-09-2002, 06:35 PM
  #34
AlienDroid's Avatar
That's it, ive decided. I'm having my engine rebuilt to handle boost and later this summer I'll be purchaseing this bad boy.
Rob, please don't make this thing tooooo expensive!!!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 05-10-2002, 01:07 AM
  #35
Nickn20's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by AlienDroid:
<strong>That's it, ive decided. I'm having my engine rebuilt to handle boost and later this summer I'll be purchaseing this bad boy.
Rob, please don't make this thing tooooo expensive!!!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">you get what you pay for, it will be worth it, trust me.
Old 05-10-2002, 01:09 AM
  #36
calebs01formula's Avatar
Been watching the kit progress Rob and you certainly have my attention, ONE QUESTION THOUGH would you be able to work a boost controller into the kit i want to run a super conservative 3-5psi for street and then the 7-9 psi for when i really want throw down. I do plan on getting some pistons as well to drop the compression a little, agian just to play it safe and add some life to the car.
Old 05-10-2002, 06:44 AM
  #37
Shorty Director
VINCE's Avatar
I was thinking the same thing...
Old 05-10-2002, 06:52 AM
  #38
Moderator
Black LS1 T/A's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by calebs01formula:
<strong>Been watching the kit progress Rob and you certainly have my attention, ONE QUESTION THOUGH would you be able to work a boost controller into the kit i want to run a super conservative 3-5psi for street and then the 7-9 psi for when i really want throw down. I do plan on getting some pistons as well to drop the compression a little, agian just to play it safe and add some life to the car.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If doable, this would be a VERY good thing. But with that much variance in boost, you'd have to very carefully select the right injectors, the fuel system would have to match the demands of both strategies, and it seems you'd need the ability to run two programs/tunes between the two boost levels.
Am I wrong, here?
Old 05-10-2002, 09:29 AM
  #39
SS00Blue's Avatar
A piggyback FI system would be required for that much variation. I did it on my Igl, but I had the EFISystems PMS. Even then it required an alternate set of parameters, and a new base fuel pressure because of the mombo (for a 2.0L) 720cc injectors.
I don't see a way into this.
SC
Old 05-10-2002, 01:09 PM
  #40
I was thinking to have it tuned to the 7psi of course but just being able to lower it to around 5psi for the street, or perhaps through 1st or second gear heheheh, traction control.
Quick Reply: LS1 Motorsports Single Turbo - 534rwhp / 687rwtq !
