after examining plugs......
Old Sep 30, 2005 | 05:15 PM
417 Motorsports's Avatar
Default after examining plugs......
i have noticed that cylinders 1-2 are black 3,4,5,&6 are tan and 7-8 are damn near white.... whats the deal? im still using the 6.0 intake manifold and the motor is stock 6.0. kinda has me a lil worried.....any ideas
Old Sep 30, 2005 | 05:21 PM
2000 Tran Zam's Avatar
thats very wierd. Does that mean cyl 1-2 are running extremely rich and 7-8 are extremely lean?
Old Sep 30, 2005 | 05:51 PM
DarkblueTA's Avatar
That's exactly what it means
Old Sep 30, 2005 | 06:32 PM
how the hell would that happen?
wouldnt the a/f ratio affect each cylinder the same way? unless theres something wrong with the spark in each of the coil packs possibly.
Old Sep 30, 2005 | 07:16 PM
DeltaT's Avatar
A white plug can also mean it is getting washed with excess fuel.
I would first try a set of new plugs, then take a couple runs and check them.
7&8 usually run the hottest cuz they're in the back of the motor, farthest from the cool coolant. 1&2 get the opposite.
You can try a hotter plug (1 range hotter) in 1&2, whatever value you are running now in 3-6, and a cooler plug (1 range) in 7&8.
If you still have problems, I'd do a compression check and leakdown test. You may have other problems.
Jim
Old Sep 30, 2005 | 07:23 PM
shudog's Avatar
Aside from the plugs looking funky, how is it running?
Old Oct 1, 2005 | 08:00 AM
1BADAIR's Avatar
Some people get there injectors flow tested and install the highest flowing ones in 7&8
Old Oct 1, 2005 | 03:00 PM
well in general its running like poo!!! lol when the engine is cold it feels to have a dead miss.. untill either A. i get it into a lil boost or B. it get to operationg temp... then it seems to clear up and run totally normal
