Motor is finally "right!!"
Old Jun 2, 2002 | 09:04 PM
cablebandit's Avatar
Default Motor is finally "right!!"
With the help of 2bseen, I have gotten my motor in...running cool and ready to start tuning. Have one exhaust pipe to get welded but thats about it. My combo for those who asked earlier:
stock block, crank and rods. Rods have arp rod bolts with Ross 9:1 pistons. Went with Cometic "boost ready" mls head gaskets and arp head studs Heads are LS1, a local guys "stage 1" with 70-71cc chambers to get me around 8:75-1 compression. Cam is 2001 ls6/z06 cam with the matching springs. I went back with an aluminum flywheel which drives perfectly normal on the street. Also have asp underdrive pullies. Using ls1edit to tune some holley/msd 50# injectors and a Charged Air systems fuel pressure regulator. I'm hoping to be able to run 10-12 psi. Using my existing walbro 340 intank with a kenne belle boost-a-pump. Did a few other little tweaks but I will post that stuff if this thing ends up producing some decent numbers/times.
<small>[ June 02, 2002, 09:05 PM: Message edited by: cablebandit ]</small>
Old Jun 2, 2002 | 11:39 PM
VINCE's Avatar
Shorty Director
Default Re: Motor is finally "right!!"
Cant wait for the results.. Were these 5.7L heads or 6.0L heads.. Thats alot of compression to drop..
Old Jun 3, 2002 | 05:58 AM
5.7 heads. Yeah it dropped a lot and lost a little bottom end torque. 6th gear is not as useable on the highway as it once was but not too bad.
Old Jun 3, 2002 | 06:38 AM
VINCE's Avatar
Shorty Director
It only matters when the boost kicks in.. The compression is just right for the boost you are planning on running.. I think you are going to be fine..
Old Jun 3, 2002 | 07:24 AM
2bseen's Avatar
11 Second Truck Club
sounds like one hell of a race to me! Glad you made it back ok and it is not running hot anymore
Old Jun 3, 2002 | 11:25 AM
Black LS1 T/A's Avatar
Moderator
You gotta love it when a plan comes together! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 3, 2002 | 01:01 PM
I dunno about sick. I'm just trying to compete with 2bseen!! His looks and sounds bad ***....should run 10s when we are done tuning. My car looks and sounds stock...should run 10s as well. I could not have done this without his help and friendship <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Don't get all misty eyed Tony....I'm still gonna outrun you!!!!!
Old Jun 3, 2002 | 01:12 PM
Ron@Vengeance's Avatar
Jerry, I have been following your rebuild man. Damn glad to see everything finally worked out. Was it the head gaskets on backward causing the problem? The SS is in the shop getting an 02 T56 as we speak. I used the TSB to get it replaced under warranty. Anyway congrats dude. Hopefully Ill be as fast as you guys one day <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 3, 2002 | 09:27 PM
Ron yes it was the head gasket AND no guts in my thermostat. This worked great for me in the past...i was running in the 175ish temp range but now it wont work. Once i reinstalled the stat...everything worked out. I'm trying to tune some msd 50# injectors now. They are gonna be way tougher than i thought. I'm gonna try to get them dialed in tho. Me and 2bseen are coming after you!! Cool deal on the tranny.....whoda thunk it?!?!
Old Jun 3, 2002 | 09:36 PM
2bseen's Avatar
Are the 50s harder to tune than the 42s in my car. Btw it is not hard to decide which car will be faster you are doing my tune also so if I do out run you once the next week you are going to want to retune my car.
Old Jun 3, 2002 | 09:39 PM
2bseen's Avatar
btw I will still look good if I get beat and you will still have a powerstroke in a ws6 that isn't washed!
Old Jun 3, 2002 | 11:10 PM
The 50s are WAAAAAYYY harder to tune than your 42s. It will not idle at all and surges like crazy till 3/4 throtttle.....but THEN it hauls ***. My fp regulator has been riding around on a FedEx truck for 4 days...can't find my address even tho fedex brought me a check from a client saturday <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> I'm gonna take the regulator out of the tank and drop my fp and see if i can get it to idle
Old Jun 3, 2002 | 11:30 PM
2bseen's Avatar
damn post again you are all 6s so the computer is doing ok and you can tune it.
Old Jun 4, 2002 | 12:53 AM
calebs01formula's Avatar
should be sick, good luck
Old Jun 4, 2002 | 06:38 AM
99taws6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cablebandit:
<strong> Once i reinstalled the stat...everything worked out. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So that was the deal? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 4, 2002 | 05:20 PM
stat and that vacuum hose. Weird about the hose. I'm surprised about the stat as i was in the mid-low 170s idleing and 185 driving....but anyway...not now <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 4, 2002 | 06:03 PM
SPRAYN's Avatar
congrats dude! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
