do i need a fuel system?
Old Jun 11, 2002 | 12:51 AM
scottywheels's Avatar
Default do i need a fuel system?
I have the 3.0 9 psi pulley on my p-1sc-h. I am now doing a 9-1 comp bottom end with je pistons and lunati rods. I have cartek stage 2 heads and cam. do you think i will need a fuel system of just an intank pump or what. thanks for the responses.
scott
Old Jun 11, 2002 | 05:58 AM
smokinHawk's Avatar
Default Re: do i need a fuel system?
Id imagine you need some kind of fuel upgrade, injectors, booster pump or larger intank.
depends on how much power your gonna make, or wanna make.
Old Jun 11, 2002 | 07:19 AM
right now i have motorsport 42 lbs injectors and the booster pump from ati. with the 9 psi and HC on the motor im looking for around 550 to 575 at the wheels.
Old Jun 11, 2002 | 08:14 AM
smokinHawk's Avatar
Thats about all you can get out of your injectors, maybe a little more. I think you'll definatly need a better pump system, for that kind of power. a dual intank or better yet a sump-gravity drain with an aeromotive pump.
new fuel lines too.
yea you need a new fuel system. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Jun 11, 2002 | 08:51 AM
I just talked to dave at cartek and they are doing a sump with a aeromotive 1200hp pump, 50lb injectors,5/8 line to the pump and 1/2 line to the fropnt of the car then modify the fuel rail to make it returnable with a fuel pressure regulator.
Old Jun 11, 2002 | 11:55 PM
KeithSS's Avatar
Yes Scott you will need a fuel system to beat SEAN <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" />
Old Jun 12, 2002 | 09:55 AM
seans car is a sled, heads cam and 150 shot and the car only went 11.3 at 120.... please that car is a slug
Old Jun 12, 2002 | 01:26 PM
KeithSS's Avatar
h/c and 100 shot. Get it right. It still went faster than your car ever did.....LOL. Just breakin your stones... It will be fast and you should be scared. On a more serious note, I really do hope your car goes good and i hope it stays together for you. You had some real S**t luck last year with those jerks. Watch out for me I'm coming for ya!!! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Jun 12, 2002 | 04:17 PM
MelloYellow's Avatar
Ya, def get a 255lph Aux pump or in-tank Walbro 340. Or else!
I saw a C5 7# burn up a piston in the first 2 days after install staying with the stock pump. It couldn't keep up.
Did you say a 3.00" pulley? I didn't know that was available. U sure you don't mean a 3.20" ?
<small>[ June 12, 2002, 04:19 PM: Message edited by: MelloYellow ]</small>
Old Jun 13, 2002 | 08:51 AM
ati said they have a 3.0 pulley for the blower. I have the 3.25 onit right now. i was only seeing 6 psi. with the 9-1 cr and the je pistons and stuff I think I might up to the d1.
