STS keeps blowing off a pipe and shredding couplers, HELP!!!
#41
Originally Posted by socalstreetracer
All I will say is good luck...oh and I will post my timeslip big and bold just for you...and it wont be a 13 trust me
How soon do you plan on running, I can't wait
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#42
Hmmm I have not had the same problems with mine.... I did run at the track last weekend for the first time and ran a un-impressive 12.89. But I trapped at 116.... I need to make some adjustments to include adding the Shaner 2-Step and the Cat replacement pipes. My 60' time was 2.7 so I have allot to do... that was also in street tires.... I will update you when I run with ET Streets and a 2-Step.. I think we will be looking at more like low 11's.
Jared
Jared
#44
I agree with what some guys have said I think you really need to get a BOV. The compressed air just has no place to go and the over the axel tube seems to be the weakest point in your system. The clamps your usuing are probley cutting in to the siicone enough to weak'n it a let it rip apart. At least the turbo isn't tring to spin backwards and rattle snake out the waste gate.
#45
lrry it sounds like the pipes do not have enough support. the turbo is producing too much pressure for the couplers to hold the pipes together. i dont think it has anything to do with the clamps, the tears seem to be bi-later which would mean twisting. on my couplers they completely expand under pressure and the entire pipe moves, i have a feeling the same thing is happening on your car. you should take your car to an exhaust shop and have them weld some more hangers for support of the pipes. hopefully this will keep them from twisting and rubbing on whatever they are. good luck.
#46
I appreciate the info guys. The pipes blew at WOT.
Deviks due: What do you mean by rattle snake out of the wastegate? When I let off the throttle it does make a crazy sound out the waste gate like its farting. Only way I know how to explain it. The tears are not from the hose clamps. There are above them with no damage at all. Im going to put the car on a lift tommorow and look hard into this. I think adding hangers and some of those neat pipe locks might be the answer.
#47
btw, if you get the hangers welded have him weld right before and after the couplers! not in the middle of the pipe!
#48
we have run cars at 8psi with no bov and have not had this happen. If you would like, feel free to email me pics of how you have it mounted. If I can help at all I would be glad to.
The silicone is damn tough, so I cant see it just coming apart easily. Make sure you have an equal amount of silicone on each pipe. Check and be sure your lower control arm isnt pulling down on the charge pipe.
http://www.trtturbo.com/images/Chris_Firehawk_012.jpg
I dont have any better pics, but feel free to call or email if I can help.
(click link)
(click link)
#49
(click link)
(click link)
#50
I will send you some pics out tommorow. I just got off the phone with Squires. They are working with me on trying to figure this out. They seem as stumped as me right now. The are thinking the short leg is blowing off the ssubframe pipe then getting caught in the tire and ripping the silicone on the other peices.
I went out this morning and was in boost testing it. I was in full boost and then lost all boost but the pipes are still connected. I got to get it on a lift to see were the leak is this time. Maybe I blew a hose out???
#51
Rattle snaking happens when the pressure in the charge pipe has nowhere to go but back out the turbo because the thottle is shut. When the air reverses it causes the turbine wheel to stop or move backwards. When this happens the exhaust gasses still have to excape but can't because the turbo is working backwards this causes a build up behind the waste gate and cause it to open in shot paulses that makes a cha cha cha sound like a rattle snake untill the pressures equalize. hope that helps some.
#53
Thanks for posting the pics Daniel.
#59
OK, I was able to load the pics.
You do not have an issue with clamps or the lip on the pipe. You have an issue with pressure. That hose has ruptured from too much pressure. We see the same thing when we are testing burst strength. Somehow your system is building up pressure and it is looking for the weakest place to escape. We are talking 70-100psi to burst a hose of that size. Some mfg. claim burst strengths up to 400psi, they are not being totally honest. This could be the burst strengt of their 1/2" ID High Pressure Hose, but not 2.5" or greater turbo hose. Check the tuning or install a BOV.
Lrry93, remember to e-mail me per our PM. We'd be happy to get you a replacement at N/C.
#60
EH??? I would think that with "70-100psi" he would have other problems than a hose bursting. If you do not have a boost gauge, it is a cheap investment and an easy way to tell if thats your problem. To get that type of pressure, he would have a clogged charge pipe upstream AND if that were the case, the car wouldn't idle.
I sincerely believe that something snagged it and tore it apart, LCA, tire, etc... IMO.
