A new project
Old Jan 12, 2006 | 11:45 AM
  #61
Kevin@W2W's Avatar
LS1TECH Sponsor
A little more progress has been made. Since I thought the set up was very cool I thought I would post these pictures in the tread so they would be a little larger.
The twins appear to have no hood line issues.
After quite a few ideas for packaging the intercooler set up the wasted space between the fender and the firewall has been converted.
Here is the intercooler mock up for the drivers side.
Next update should be cage and suspension
Old Jan 12, 2006 | 11:52 AM
  #62
NA$TY-TA's Avatar
That Is Looking Sick.............
Old Jan 12, 2006 | 12:01 PM
  #63
Hugger Z's Avatar
Looking great! I can't wait to see future progress updates. You guys have any needs for more help there? I need to find a way to support my car habit!
Old Jan 12, 2006 | 01:29 PM
  #64
2002 Trans Am's Avatar
Sweetness!!!
You guys gonna send that body/frame off to get blasted to get rid of the rust?
IC locations are pretty trick
Old Jan 12, 2006 | 06:23 PM
  #65
Reckless's Avatar
Super Moderator
Looking good Kev....can't wait to see it in person!
Old Jan 12, 2006 | 10:11 PM
  #66
Keith's Avatar
Nice!
Kepping the stock subframe?
Old Jan 13, 2006 | 07:13 AM
  #67
chuntington101's Avatar
any more info one the engine (price?)?????? pleeeeeeese?
Chris.
PS. oh yeah, and its looking VERY good!
Old Jan 13, 2006 | 08:08 AM
  #68
sniffin94's Avatar
That is probably the coolest intercooling mounting ever, awesome job W2W
Old Jan 13, 2006 | 12:10 PM
  #69
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice. is it going on, or just getting mocked up? I'd be media blasting or even dipping the car potentially.
Old Jan 13, 2006 | 12:13 PM
  #70
Old Jan 19, 2006 | 09:44 AM
  #71
Kevin@W2W's Avatar
LS1TECH Sponsor
I'm not sure what we are doing as far as clean up. The main strategy with this car is sleeper although it would be nice to be super clean. Maybe Kurt can chime in with more plans.
Here are a few more.
Here is a few of the intercooler plumbing going together
What's cool about this pic is what you don't see
Ah, there is the main hoop
Old Jan 19, 2006 | 09:47 AM
  #72
Kevin@W2W's Avatar
LS1TECH Sponsor
Chris.
Hey Chris.
The Nova engine will be a similar version to our 1000 hp able boost ready crate with a few tweaks and a dry sump system. You can check it out here in case you missed our other thread.
http://www.w2wpowertrain.com/pc-98-7...ong-block.aspx
Old Jan 19, 2006 | 10:15 AM
  #73
sniffin94's Avatar
whatever you do, you have to keep that steering column and sterring wheel that is in the pictures
Old Jan 19, 2006 | 11:45 AM
  #74
1CAMWNDR's Avatar
Very cool . Leave the exterior alone!!! Just fix any rust in critical areas!!! If any rust is fixed on the body panels paint that section primer and leave it. Bench seat and keep the column shift and stock steering wheel.
Old Jan 19, 2006 | 11:52 AM
  #75
NOSjohn's Avatar
Restricted User
I can't agree more...sleeper image is GREAT !
Old Jan 19, 2006 | 11:56 AM
  #76
BLWN1's Avatar
Sleeper image or rat rod...? Rat rod would be cool, but the things coming from that shop, I wouldn't dare not make it spectacular! Just keep it green, all the green ones have become red or black now....
Old Jan 19, 2006 | 12:59 PM
  #77
Well seeing what your shop did to Roofer Dave's car I think you guys would be nuts not to pimp a deep metallic paint....but if your gonna keep the sleeper look, might as well still blast, primer, and then rattle can it if you want it to be a sleeper....just don't let it rot away
Old Jan 19, 2006 | 01:29 PM
  #78
NA$TY-TA's Avatar
bad *** man that sleeper look is awsome........
Old Jan 19, 2006 | 02:02 PM
  #79
427's Avatar
427
We will clean and stop all rust, but the original paint, or lack of it will stay.
Bench seat rebuild is in process.
Will have vintage AC system(I am the driver).
Looking for a replacement steering wheel, but the column stays as is.
With the hood up the sleeper value will be gone! Hood down the car will look innocent, probably sound like your typical 1000hp cruiser.
Can't wait to drive it home for the shakedown runs, my wife says I can't park it there!
Kurt
Old Jan 19, 2006 | 02:21 PM
  #80
1CAMWNDR's Avatar
Need to put some (probably several on each side ) very quiet mufflers under it with dual cut outs for play time .
