A new project
Old Oct 6, 2005 | 10:55 AM
Kevin@W2W's Avatar
LS1TECH Sponsor
Default A new project
Should be pretty fun
http://www.w2wpowertrain.com/t-novabuild-2.aspx
Old Oct 6, 2005 | 11:02 AM
LSONE's Avatar
That thing is going to be amazing, I'm looking forward to seeing how that fuel setup will work, I've heard of it before but never actually seen it. Very cool!
Old Oct 6, 2005 | 11:17 AM
93formto98T/A's Avatar
Just.....WHY?
Old Oct 6, 2005 | 11:20 AM
DERTY's Avatar
The Bull
Kev, I'm sorry this is LS1Tech. Overhaulin is found here> http://tlc.discovery.com/fansites/ov...ck=tlc_leftnav
I'm sure it will be awesome when it's done though.
Old Oct 6, 2005 | 11:21 AM
Kevin@W2W's Avatar
LS1TECH Sponsor
Originally Posted by 93formto98T/A
Just.....WHY?
Why not?
Old Oct 6, 2005 | 11:22 AM
kp's Avatar
kp
I think its pretty cool.
except whats up with the 300hp pump gas limit, if I was driving that thing around the C16 tank would be empty pretty quick
Old Oct 6, 2005 | 11:25 AM
NA$TY-TA's Avatar
ha ha ha ha
Old Oct 6, 2005 | 11:31 AM
Kevin@W2W's Avatar
LS1TECH Sponsor
It will be powered by a LS1 engine
At 300 hp the Bigstuff will transition to a 75 percent C-16 mix.
Should make for the best of both worlds considering we can toot around on pump gas then when some young ls1 punk pulls up we can put a whoopin on him without flipping a switch
Old Oct 6, 2005 | 11:33 AM
NOSjohn's Avatar
Restricted User
Dang, that is a rare find. Keep it the original color! Also, are you keeping original tire size with the hub caps? Super sleeper in that form for sure!
Old Oct 6, 2005 | 11:39 AM
Not trying to bash the project in any way....IMO the awesome powertrain setup would be better suited in a late model GM but it is unique. But each to his own. Carry on..
Old Oct 6, 2005 | 11:43 AM
Kevin@W2W's Avatar
LS1TECH Sponsor
Was just curious. Didn't take it as a bash.
The car is something different we wanted to put together for the Power Tour opposed to our other high dollar builds.
For the most part the cars existing exterior will remain including the paint.
Old Oct 6, 2005 | 11:49 AM
427's Avatar
427
Kevin, the C-16 starts adding in above 300hp. It is a 25%pump 75% c-16 mix. The C-16 tank at 10 gallons will probably last all of Powertour without refilling.
Rough calcs.
A 1000hp engine will need 550#hr of fuel to run at wot(1000hp). 10 gallons of C-16 is about 80 pounds. We will be burning about 9 pounds a minute at wot. That gives us almost 9 minutes of full throttle operation before the C-16 tank needs refilling. On power tour a 5 second burst of WOT could get you a 4 digit ticket! With a 10 second ET we could make about 50 1/4 mile runs on one C-16 tankfull.
Kurt
Old Oct 6, 2005 | 12:07 PM
Whistler's Avatar
Sawzall and Welder Mod
That's awesome.
Old Oct 6, 2005 | 12:08 PM
smokinHawk's Avatar
intersting but if you want it to move forward instead of sideways those big tires are going to give it away, least to us smarters peoples
Old Oct 6, 2005 | 12:17 PM
qqwqeqwrqwqtq's Avatar
That's a sweet project.
I vote for keeping the paint original, and keeping the hubcaps on stock widened wheels.
Old Oct 6, 2005 | 12:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That's a cool idea Jim except I wonder if those are 14" rims.
Old Oct 6, 2005 | 12:48 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
I believe we will do a factory rally wheel with the rear widened to accept a bit bigger tire.
Personally I think the hub cap idea would be cooler.
Old Oct 6, 2005 | 12:51 PM
Big Mike's Avatar
Very Cool!!!!!!!!!!!!
Old Oct 6, 2005 | 12:59 PM
Got Me SOM's Avatar
that's about as clean a Nova as you can find unmolested. Curious why you set the hp so low before using c 16..
Old Oct 6, 2005 | 01:10 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
We assume prior to testing 300 is when the mix should start coming in.
Baseline dyno numbers as of a few minutes ago.
RWHP 88 !!!!!!!!!
1/4 mile ET test 20.39 seconds !!!!!
Who wants some
