Any ideas why I'm running lean?
New 42# injectors were installed with the supercharger
Fuel pressure at the manifold is about 52-55#s
I've been all over the motor with starting fluid looking for a vacuum leak..didn't find anything.
Had someone with a scanner log my LTFTs during a street run, they are negative for the most part.
Called Magnuson, they say that they've been sending out the same tune for years. Supposedly no way I could have gotten a bad one.
Here's my dyno chart. We stopped at about 3.5K due to the AF not coming down.
#2 - what vehicle is this on? LS1 base fuel psi is 58-60...
#3 - add a rising 1:1 regulator
and correct it if there's any issues. Gotta luv that kind of support. Unfortunately, I'll be without my car for about a week while this takes place. You don't make a full pull on a blown motor when it's that lean or you may be picking up parts after the run. They were smart to stop until they figured out what's going on. My first thought is that the tune may be made for a boost referenced regulator and this one isn't.
Jody
Jody
Jody
