Lower mounted Turbo guys, got question.
P.S. My turbo is under the driver side headlight
Hellraiser also had this issue on his kit as well.
My oil drain line isn't at the greatest angle, but it works pretty good. I don't have a scavange pump, but I do run a restricted feed line and that helped a lot. Restricted it to a .109 opening.
J
I also run -4 out the oil filter fitting teed off to -3 into each turbo. No restrictor. The -3 line is restrictor enough.
