spark plug reading question
Old Oct 28, 2002 | 01:28 AM
1dirtyZ's Avatar
Default spark plug reading question
i took my plugs out for inspection and i see that the electrode is white / light tan and the base is black ( like really black).
i just had the car dyno tuned and A/F ratio was set to 12.5 . should i be worried? is this normal or should the electrode be darker?
the car has an ATI kit running 10psi
Old Oct 28, 2002 | 06:56 AM
LIGHTNINROD's Avatar
Default Re: spark plug reading question
I hope they don't look like 'these'!
http://198.65.157.241/forums/showthr...ht=spark+plugs
Dan
Old Oct 28, 2002 | 08:14 AM
1slowCamaro's Avatar
That sounds about what mine looked like when I just changed them. I could not tell you wheater or not its good. I was a little worried also. When I use to be a nitrous freak I had a plug burn like in that picture. Dont know what happened to the tip of it. Woops! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Oct 28, 2002 | 10:29 AM
1dirtyZ's Avatar
i still have the tips on , but the color was similar to the ones you had ( more white than green though).
what happened to your plugs! toooo lean?
Old Oct 28, 2002 | 11:19 PM
MelloYellow's Avatar
They seem to like Denso plugs for FI over there. Anyone have any opinions or experience with them?
Old Oct 29, 2002 | 12:51 AM
1dirtyZ's Avatar
same question , and are there any colder plugs than the tr-6?
Old Nov 1, 2002 | 07:09 PM
The NGK BR7EFs and the Denso IT24s are both colder than the TR6s.
Dan
Old Nov 1, 2002 | 09:13 PM
What are the best ways to determine you need a colder plug than the TR6's with FI?
Old Nov 2, 2002 | 09:42 AM
superchargedZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow:
<strong>What are the best ways to determine you need a colder plug than the TR6's with FI?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good question, I would like to know as well?
Old Nov 7, 2002 | 08:11 AM
<strong>What are the best ways to determine you need a colder plug than the TR6's with FI?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The "best" way is to do a WOT 1/4 mile run, shut the eng. off, coast to a stop, pull a plug and 'read' it. If it's blistered, has a cracked insulator, and/or too 'white' in appearance then you're plugs may be too 'hot'.
If you hear detonation and then pull a plug, it may be too late..............see the link above with pics.
Dan
