SDCE & Belt Slip
Old Oct 15, 2005 | 09:59 PM
Ed Blown Vert's Avatar
Default SDCE & Belt Slip
I have been checking everything trying to figure out why I only get 7# with a 7.25 crank pulley and 3.4 blower pulley.
And I noticed belt dust around the blower. What can I do to fix that?
I remembered on my old motor with the MMS pulley (7.85) and a 4.10 crank pulley I saw 5-6# (48,670 rpms).
Then after the swap to 6.0L heads and the blower pulley to 3.7 I saw almost 10# (53,354).
So I would think with the SDCE (54,204). I would see close to 10# :dunno:
Old Oct 16, 2005 | 01:16 PM
frcefed98's Avatar
With the 3.4 on my ATI SDCE set up, I was pushing 15psi reliably. No belt slip.
348, ported and polished 6.0 heads, and a huge cam 233/244 .578/.602 115
Its on KP's car right now, with the 3.7 pulley and he's pushing 13psi with that one using my old belt.
If he goes to the 3.4 he'd be pushing 15+psi
Did you preload the tensioner? It has to be set up wrong still, its pretty simple to figure out tho?
Old Oct 16, 2005 | 02:35 PM
strokedls1's Avatar
Your probably talking about the d1sc and he has the p1sc. That is why when you said you were going to swap to a 383ci I said you should consider a d1sc head unit. The p1sc I don't think puts out enough to get you any where near 15 on a good flowing 383ci.
Old Oct 16, 2005 | 03:36 PM
I'll double-check the tensioner. But ya, its not that hard to set-up. But if you got 15# with a D1. I would think I could get 10# with a P1
Well, I may have to switch to a D1. Just keep the P1 when smog comes around.
Old Oct 16, 2005 | 04:33 PM
Spdmn75's Avatar
I'm seing 12psi @6500 with a P1 and 3.4 SDCE,stock heads though
strokedls1's Avatar
Yes but he got 15 with a 346 not a 383. There is a big difference. You should call rob at strictly for a price on just a d1 head unit. I know he gets some great prices on the ati stuff.
Old Oct 17, 2005 | 06:16 AM
EPP's Avatar
EPP
Question
It also sounds to me that your P-1SC has run out of breath, but:
you did mention blower belt dust though, so you have to be having belt slippage. Bob
Old Oct 17, 2005 | 09:32 AM
Blackbird's Avatar
what do you have your tensioner set to?
take a pic so we can see where it is right now.
Old Oct 17, 2005 | 09:54 AM
kp's Avatar
kp
I'm seeing close to 15psi with a 3.7 in this cooler weather, I log boost every pass and I get zero slip but I do get a little belt dust. I think unless everything is perfectly aligned you have to get some dust from normal wear and tear.
I would guess that that P1 is just running out of steam, crank up the tension and see what happens though. If its way too lose it could slip I guess..
Old Oct 17, 2005 | 10:02 AM
Blackbird's Avatar
It can definetly slip. Until I had enough tension on my tensioner it would slip. I was one of the first to have this setup years ago and didn't understand how to set it properly. Once I got enough preload set then it worked excellent. A few folks have made over 600rwhp with the P1 so I would think he isn't out of blower yet.
Old Oct 17, 2005 | 10:06 AM
Well, the mark is about on the 17. Just past 15.
I'll post a pic when I get home.
So should I adjust it closer to 20 to make it tighter?
Old Oct 17, 2005 | 10:09 AM
Bob. I PM'ed you on the other board for a price of a D1 head unit.
Old Oct 17, 2005 | 10:10 AM
kp's Avatar
kp
I think ed has made close to 600rw already at where its it at now. I have tried with these P1s and over 55K they pretty much just start making more heat. IMO he needs more blower but I'm no expert
FWIW this applies to the P1 on an F-body, on a P1 with an A&A C5 kit you will see a lot better numbers because he air intake is way less restricted plus a good sized IC and very little piping. The F-body air inlet is a killer plus the twin ICs and a mile of piping puts the hurt on a P1.
Old Oct 17, 2005 | 10:21 AM
I don't know if those dyno number are right. At the track my mph was only 90 in the 1/8 :dunno:
I was able to get a few runs on a dynojet. Numbers were like 480 rwhp. :wtf:
And with the last motor I got 550 rwhp.
Old Oct 17, 2005 | 10:28 AM
kp's Avatar
kp
I thought you made close to 600 with the new setup - I must be thinking of someone else OK, I missed the the 'numbers before the 383' in your sig and figured 550 on a mustang was pretty good.
You should be making close to that with no blower so something is wrong.
Old Oct 17, 2005 | 10:32 AM
I thought I was close to 600 rwhp. The dyno dynamics dyno showed 550 rwhp. I always thought that the dynojet read higher. :dunno:
The numbers "before the 383" were about the track numbers.
I did hit 505 rwhp on the dynojet, but the AFR was 12:1. I set the AFR to around 11:1 and ended up with about 480 rwhp.
Old Oct 17, 2005 | 10:47 AM
kp's Avatar
kp
OK, the track numbers were from the old setup.
480 on a dynojet is pretty low, I would think with 7-8psi on that motor you should be over 550rwhp on a dynojet. You may be able to get a couple more PSI if you max the P1 but I really think a D1 will help you out a lot.
Something is up only running 90mph in the 1/8 though, even at 4000lb raceweight thats still under 400rwhp.
Old Oct 17, 2005 | 10:52 AM
Ya I don't get it. I would think I would be just as fast or faster than the last setup. There was a 355 LT1 shooting a 100 shot running almost as fast as me. I had to shoot a 50 shot just to make sure I would beat him. I ran a 95 on that run.
Old Oct 17, 2005 | 10:56 AM
kp's Avatar
kp
you dont happen to have any log files from the dyno or track do you?
Does your boost seem to vary a lot? Are you just looking at the gauge or do you have a peak/hold gauge or are you logging it somehow?
Old Oct 17, 2005 | 11:00 AM
I have some logs from EFI I can post when I get home.
The boost is smooth all the way to 7# on the dyno. Next time at the track I will record the gauge.
Here is the dyno also showing the boost.
http://www.ls1.com/ed/383-dyno.jpg
