High HP dyno charts?
No torque reading on that one sorry...
-348ci
-8.25:1
-730-754rwhp
-I recall seeing like 700 tq on one pull
Anyway, I want 800 - 1000 whp, but limit the torque to 750 ft/lbs max. This car will be lighter, so the tranny should handle some extra torque.
That is why I want to dyno charts, to see what combinations make good top end power, but limit the torque. I have also been thinking of going with a short stroke engine. Lunati goes all the way down to 3.2". I will probably use the new World block that is coming out, then I should be able to do a 4.125" bore with 7.5:1 compression (again purposely on the low side).
take a look at wheel to wheel. they have a LS1 thats running close to 1500bhp i think, but thats on an iron block, but you should be able to get 1000bhp out of an ally. also they are building a twin supercharged 402 ls2 thats making close to 1000bhp already! and their using twin rotex centrifugal blowers so the torque should be lower but still with a strong to end!
i have also sent you a PM about the 'box!
thanks CHris.
PS hope you keep us all updated. sounds a very intresting project!!!!
GTB that is about exactly what I am looking for! Do you have a link to your mod list? What is on the right axes? I am guessing you didn't make 2,700 ft/lbs of torque
JZ - I know the 61's would get me to 800 whp easily, they will starting to get taxed at the 1k mark, which I may eventually go for. I will be running pretty high boost with the low compression. I haven't actually thrown the numbers on a compression map yet because I am still up in the air about the engine. I have a 61 on my current car and really like it. 498 whp at 25 psi on a 2.4l 4 cylinder.
chunt - it is going into a car similar to a Ultima
how far are you along with yourultima, should be a sweet project, good luck.
