What is the highest Boost I can run?
Old Nov 11, 2002 | 04:51 PM
Axle's Avatar
Default What is the highest Boost I can run?
What is the highest boost on a Supercharger or Turbo can I run safely if my cylinder heads are 10.8.1 compression.
TKS.
Old Nov 11, 2002 | 05:40 PM
vetterdstr's Avatar
Default Re: What is the highest Boost I can run?
5 PSI
vetterdstr <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Nov 11, 2002 | 07:08 PM
y2khawk's Avatar
You can't simply answer the queston with a boost number.
Too many factors come into play....
Pump gas?
race gas?
intercooled?
how much advance?
how much power are you after?
what cam?
turbo or blower? (it makes a difference)
bottom end??
boost is just a number <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 11, 2002 | 09:35 PM
Axle's Avatar
Thanks guys. I was hoping for 7psi. Maybe with more info I can get a better picture. Looking at the ATI Supercharger (D-1SC)with intercoolers. Run on pump gas and my cam specs are 222/222 LSA114 and keeping the bottom end stock for now. Can I run 7psi if I don't go to the track much.
TKS.
Old Nov 11, 2002 | 10:09 PM
vetterdstr's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
[QB]You can't simply answer the queston with a boost number.QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LPE does.... they install a Roots type blower with 5 lbs of boost and thats it....
He didnt say he had mods, race gas, cam, or if he was spraying NOS... he said he had 10.8 compression.
Old Nov 11, 2002 | 10:21 PM
y2khawk's Avatar
Welp, guess i don't know what i'm talking about then, cause if LPE says so it must be true <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
like i said, it depends. You can't say 5 psig and no more. Application specific, everytime.
Axle
Not going to the track isn't gonna change things. A D1 at 7 psi is a decent amount of flow, figuring the heads flow pretty well, and you've got some kind of exhaust. Making 7 psi on the gauge is alot of air through the motor. 10.8:1 CR is a bit high for that level, but it can be done w/ the right tune.
How much power are you after?
Don't forget the fuel system <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 11, 2002 | 10:50 PM
Stenod's Avatar
LS1TECH Sponsor
Well, i am up to 10PSI on a STOCK motor!!! And it runs great. ah ha
Maybe my tuner is just really good.
We'll see,
I need to get some new dyno #'s on my 10 pounds
Joe <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Nov 11, 2002 | 11:04 PM
White SS's Avatar
2000 Twin Turbo Trans Am - Firehawk #80
700 RWHP/715 RWTQ @ 15 psi on Mustang dyno
MI plate: TRBOHWK
10.000 @ 142.61 - 1.492 60'
Black, 6-Speed
You need to put your car on a diet <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
9.XX will be there <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Nov 12, 2002 | 05:21 AM
vetterdstr's Avatar
I understand what you guys are saying. I too run my car with more boost (9 lbs) than what is safe for the stock bottom end LS1 Engine. That does not make my tuner any better than anyone elses.
I was addressing the question as asked which was "what is a safe boost for 10.8 compression"?
Old Nov 12, 2002 | 05:35 AM
smokinHawk's Avatar
I think you can run upto 35psi, for 5 seconds. on 89 octane. Only once. <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
<small>[ November 12, 2002, 05:36 AM: Message edited by: smokinHawk ]</small>
Old Nov 12, 2002 | 02:20 PM
Axle's Avatar
Thanks guys, I appreciate the info. I just have your typical bolt on mods with Stage II heads/cam. I was hoping for the 500RWHP with the SC as I'm dynoing at 362RWHP and 380RWTQ SAE Corrected at this time (automatic tranny) as I need more tuning still.
So with good tuning, I can run higher boost? <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Please explain how as I thought the compression was the only factor as to how much boost I can run.
TKS
