big injector questions, fuel pump question
i also need a fuel pump, i would like to see it quite a bit bigger than whatever is in there, right now i am loosing presure at the shift points and i am sure i will want to get more power some day, maybe a small wet nx kit. anyone here know anything about fuel systems in the trucks? should i go intank, or inline or what?
<small>[ November 17, 2002, 02:30 PM: Message edited by: parish8 ]</small>
Do you have an upgraded intank now??
I had great success w/ the 42's i had last year. And since going to the 96's i've had equal success. Even w/ the bigger cam, low CR, and fire hose injectors the A/F is right on and idle is steady. I did however have the injectors individualy flowed to get an accurate flow number for each.
The fuel system on the trucks is very similar to the cars, better for boost actually. The regulator is already on the fuel rail and referenced to the manifold. A decent intank will do well for you. Might even consider a dual intank if you plan to hit it w/ a decent sized wet shot.
prety sure the 50's will hold me but i really want to go all out on the fuel pumps just in case i want to hit it with i fat shot someday. is there any chance the duel pumps will overcome the return line? i doubt anyone knows if the duel set up that i have heard of will work in my truck, may need some modifying.
<strong>You should have no problems w/ the 50's. They are however, the largest you can go w/ high-Z injectors. After that you'll need an injector driver box, or go to a low impedance capable EFI system.
The fuel system on the trucks is very similar to the cars, better for boost actually. The regulator is already on the fuel rail and referenced to the manifold. A decent intank will do well for you. Might even consider a dual intank if you plan to hit it w/ a decent sized wet shot.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Harlan, let me get your opinion:
I have a 422 now with the D-1SC and 42# Injectors.
Before, with the 346, and 4.10" pulley, I made 5 PSI at ~ 6K RPMs and stock exhaust. Moving to the 3.20" pulley, I made 12 PSI with the stock exhaust; 9.5 to 10 PSI after putting on headers.
After putting the 4.10" pulley back on for my initial tuning with the 422, I see about 3 PSI at 6000 RPMs.
Questions:
1. Do you think the 42# injectors will handle the 422 and the 3PSI boost level?
2. At what boost level do you think I may get by if I moved to 50# injectors?
3. Do I just need to plan on low impedance injectors and drivers if I want to run about 7 or 8 PSI everntually?
Thanks, man.
Gary
