Turbo mounting cause oiling problems??
Old Nov 20, 2002 | 03:12 PM
smokinHawk's Avatar
Default Re: Turbo mounting cause oiling problems??
mine smoke a little on idle when the lines wernt quite right, thought i blew the head gasket.
Old Nov 21, 2002 | 12:49 AM
LS1astro's Avatar
Default Turbo mounting cause oiling problems??
Has anybody had any problems or know if it would cause any problems if you mount your turbo at like a 45 degree angle. Would everything still oil properly?
Old Nov 21, 2002 | 10:34 AM
99GMC Can's Avatar
I've never seen an install where the shaft was not parallel to the ground. Oil flow is critical. I have seen turbo bearings go because the drain into the pan was in line with a connecting rod and that cause a restiction.
You got a LS1 in an Astrovan? Cool
Old Nov 21, 2002 | 01:25 PM
LS1astro's Avatar
I have the shaft parallel to the ground its just the oil inlet and the drainback are at a slight angle
Old Nov 22, 2002 | 12:01 AM
zturbo's Avatar
It should be in a 15 degree of centerline to be best. Is it cause it is to low or is it because you don't have room? other solution mount super low and get a scavenge pump to mount on the motor (razor, etc...)
Old Nov 24, 2002 | 12:04 AM
LS1astro's Avatar
Yeah I dont really have the room and I really dont wanna run a pump. Seems more complex and to many possibilities for problems. How low can you mount them befor you do need a pump?
Old Nov 24, 2002 | 01:21 AM
zturbo's Avatar
Needs to be above the oil line by a bit so it is a downward line to the oil.
Is it you need the turbos low or just the angle isn't right? The thing you could do is create a resivoire and have it go to the tank or whatever then drain to oil pan from there just to give yourself a little more area for the oil. If you are mounting the turbos low make sure to use bigger drain back line so it has less restriction.
Steven
Old Nov 24, 2002 | 11:37 AM
LS1astro's Avatar
Its both that I have a problem with. You would think since its an astro I would have plenty of room but I dont. I could go a diffrent route and mount the turbos further back but I think that would cool the exhaust gasses too much. Can anybody tell me how far back the turbos are from there heads, as far as how far the exhaust has to travel? My headers are Jethot coated so it helps alittle.
If I have to go that route, how much are the oil pumps you guys are using?
