loosing boost
Old Nov 23, 2002 | 11:05 AM
sscamaro387's Avatar
Default loosing boost
ok, I have done everything to try an figure out why I m only making 3-5 lbs of boost, cause the gage is fine, hose clamps tight. everything, but i got my car dynod on monday, and I onloy got 354 rwhp, and 364 rwtq. I have a P-1 Kit, with a 3.0 pulley on it. so i should be at 12 psi or so. Any suggestions????
Thanks ahead of time
ps. When i reached 4500 rpm's, the curve hella dropped. on hp, and torqe.
Old Nov 23, 2002 | 04:09 PM
Just Chris's Avatar
Default Re: loosing boost
Did you EVER see more than 3-5 pounds or did it suddenly drop? Does your surge valve close under boost? I live in Santa Clara and also have the ATI kit, maybe we could get together and figure this thing out.
Old Nov 23, 2002 | 04:29 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Just Chris:
<strong>Did you EVER see more than 3-5 pounds or did it suddenly drop? Does your surge valve close under boost? I live in Santa Clara and also have the ATI kit, maybe we could get together and figure this thing out.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I never say more than 5#'s, not sure if the valve is closing?? when i disconnected it, I can move it open/closed freely. and i work in sunnyvale, and live by Valley Fair. So let me know, I get off work at 5.
Old Nov 23, 2002 | 04:56 PM
White SS's Avatar
<strong>Did you EVER see more than 3-5 pounds or did it suddenly drop? Does your surge valve close under boost? I live in Santa Clara and also have the ATI kit, maybe we could get together and figure this thing out.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My boost suddenly drops I think it is from belt slip how do I check to make shore the surge valve is working right?
Old Nov 23, 2002 | 05:35 PM
Blackbird's Avatar
my powerdyne only makes 5psi peak and the car is making 433/432
you definetly have something going really wrong.
who did your tuning. can you post the graph?
I am in San Jose if you need help.
Old Nov 23, 2002 | 05:40 PM
White SS's Avatar
I think he has somehing else going on to because my p-1sc w/3.1 pulley I was putting those numbers down by 2300rpm (stock internals / untuned)
<small>[ November 23, 2002, 05:41 PM: Message edited by: White SS ]</small>
Old Nov 24, 2002 | 12:00 AM
LS1astro's Avatar
Belt Slippin?
Old Nov 24, 2002 | 12:45 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1astro:
<strong>Belt Slippin?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Belt not slipping, everything is right. as far as i can see. just can't figure out what is the reason why it isn't making enough boost, and the dyno shows that there is a problem.
