help a girl out......easy question :)
i've heard 10 is good....
i also have a sheet metal intake and the heads/cam.
any info would be great1
thanks
trish
<strong>what's so funny</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should be pulling 20" of vacuum minimum, with a stock intake/cam at idle. You specified the intake, but haven't specified the cam, so any guess is just pure crapola, at best.
As far as boost, it should be the same as the kit is rated with the pulley on the car... 4lbs.?
SC-
<small>[ December 20, 2002, 03:09 PM: Message edited by: SS00Blue ]</small>
6-8 lbs crapped out the motor? I would think it should've been able to handle that. Was it stock compression? What was done to add fuel? FMU? Programming?
Just curious.
i do think the whole question is about boost though.. how much air pressure above atmospheric you can push into an engine.. well the more.. the better <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> but much over 8 or so and odds are you are on the thin end of reliability... on a stock ls1 anyways.
I was able to run 6PSI of boost all day without any trouble. Not even in the high 80's did I have any problems. However we had someone tune a guys car that was suprcharged and the motor let go from detonation. You really need to make sure you have enough fuel and that the timing is where it should be. Otherwise even 4lbs can cause you problems.
nope i'm talking about on the left side of the gauge...u know at idle and cruising....no vacuum leaks and good motor is higher vacuum it is pulling...i dunno if it is measured by pounds or what...a guy w/a stang told me he had 10 or so and that was good for his car.
i have the sheet intake, heads, cam, 38 lb injectors, computer tuning, etc etc...
i think i might have a kink in the line..that is what the hubby says....i notice at start up when the engine is cold and when it is really cold outside that the vacuum is really low.....and once driving around it gets 12-15 or so.
so the question i had was what is a good vacuum number to have to ensure no vacuum leaks and a good running motor...
i hope that make sense and thanks for the replies....u guys always help me out
thanks!
trish
2 to 4 inches (motor in good condition)
At a idle a motor should have (stock)
17 to 21 inches of vacuum
A motor with a non stock cam I've usually seen at about 15 - 17 inches of vacuum
Heads and intake will bring it lower so 12-15inches should be okay <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Vacumn is normally measured by inches of mercury...in/hg...10 inches is WAY TOO LOW!!!
Even for a supercharged engine. Normally asp. engines should run between at least 17 inches to about 20 or 21 inches. Of course a lot has to do with the cam...the bigger the bump stick the less vac. At 10 inches you would have one HELLUVA intake leak or really crapped out valves or a cam designed for a Pro-stocker. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I would have to guess you might be ok with 15 or more inches of vac. hope this helps!!!
Jason
Like I said before, without knowing the cam timing and because you have a sheetmetal intake, ported heads, etc. ANY guess at idle vacuum is pure crapola. No one can possibly know.
My 347, 12.5:1 Ford had a .680/.680, 280/280 @ .050 cam and the thing only pulled 5". I built a 455 for my friend with a reasonably small cam with lots of exhaust timing and it only pulls 10".
It's just not possible to tell without info. I will say that if you are seeing a rise in vacuum of much more than 1 or 2" between start up and full warm, you are likely fighting internal engine wear. The heat is sealing up some leakdown most likely.
Just can't tell from more than 3' away from your car. Sorry.
SC-
<strong> Trish,
SC- </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">what exactly does that mean...i don't know too much about cars..u saying there is a leak of some kind somewhere u think?
and thanks for the help on this
Why the sheet metal intake?
That alone will make your car hard to compare to other's normal vacuum.
it says boost in the middle
left side says vac and goes to 30 or something like that and the right side says press and goes to 30 also i think.
i dunno why we got the sheet metal....i was told it would work good w/my blower. my husband is the one who builds it and i never have understood how the car works or what combinations are good or anything about tuning and the cars needs.
thats why i come on here and try and understand it if i can.
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
trish
