Timing v.s. boost...
My goal is, and has always been, 450 RWHP. Right now I managed that with 5.5 psi and a tune by yours truly with LS1 edit. I have 24 degree's of timing at WOT.
If I back the timing down to 18 degree's I need 7 psi to make my 450 RWHP.
Which way would be the least detrimental to engine life? Assuming all other things are equal (driving habits, track time, etc...).
Just my .02 cents
I think it would make more power with 18 degrees of timing and 7psi than 24 degrees of timing and 5.5 psi due to the efficiency of the combustion chamber (alot of timing is not needed).
I do know that i could tell a difference in spool up times when my timing was lower... i got boost noticeable sooner with less timing due to the hotter exhaust gases.
this is a good topic, how sure are you about the 6deg=2psi
Stock compression, 91 octane gas (******' Utah, I swear to GOD), I run 3 psi on the 91 and go to 5.5 with a mix of 91 and 100 in the tank. I've only had the kit installed for about 2 weeks, but no problems as of yet.
Hehe, I got the excat opposite suggestion on that "other" board. Keep em' coming. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
- Dug
2 PSI boost is a lot more power than 2 degrees of timing. No... I can't say how much.
Perhaps a shop that has time on their hands to test those things can answer that question.
That being said, I've heard too LITTLE timing can adversely affect more than just power... that too little can ALSO create detonation. Is that a crazy idea? What happens when timing is reduced to too little?
Jose
Sum it up, go the most boost with the most timing with 0 KR, that's the sweet spot. HTH
edit: Ha Ha, can't spell!
