Misconceptions / ATI-D1SC
My Kit.
ATI-D1sc 8lb tuner.
42.5lb inj
walboro inline f/pump
Leave me suttin to read here fellas.. imput is appreciated. kyle 98 TA
Look and see what size pully you have on the charger.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Alex
But on a completely stock engine (like mine) with stock exhaust manifolds, the blower should make what it is rated at. For reference, my D-1SC came with the 3.60 pulley. It makes exactly 8 pounds max at 5,900 RPMs.
Mike M
A supercharger will only flow a certain CFM at a certain RPM.
Lets say that you have it pullied to flow 1000 cfm at 6k rpms. You see 9psi of boost, meaning that not all 1000cfm is getting into the cylinder. If it was, you would have 0psi boost.
Now if you port the heads and see 6lbs of boost, you are flowing more air and using more of the available CFM, rather than it backing up in the intake manifold.
Alex
8 psi on unported is less air than 5 psi on ported heads with the same blower pulley.
If you were to increase your boost on the ported head car to 8 psi from 5 psi you would have a hell of a lot more air in there and it would stand to reason that you could damage your engine.
Like INTMD8 said,the boost reading is air not being used by your engine.
