which way to go
Old Oct 27, 2005 | 12:37 AM
venom ws7's Avatar
Question which way to go
ok guys what setup to go
1- full boltons - TRAK - AFR 205 - 100 shot
OR
2- full boltons - forged motor - f1 procharger
What do you guys suggest
i want the best setup for top speed runs cuz we have alot 500hp - 600hp supras and skylines around here
thanks in advance
Old Oct 27, 2005 | 12:46 AM
2000 Tran Zam's Avatar
f1 and forged short block will make more power, and is always on tap. will cost more though.
Old Oct 27, 2005 | 12:48 AM
RelentleZ's Avatar
#2 by a long shot. boost just makes more sense.
Old Oct 27, 2005 | 12:49 AM
Got Me SOM's Avatar
you'll have to do a lot of mods to get the f1 to fit, and you'll lose some of your creature comforts.
big difference between running a 100 shot and running a f1.
Old Oct 27, 2005 | 01:33 AM
venom ws7's Avatar
Default thanks
thanks guys
with the f1 setup will i have to remove my a/c
Old Oct 27, 2005 | 01:42 AM
venom ws7's Avatar
if the f1 setup it will stock heads and cam
Old Oct 27, 2005 | 06:18 AM
MOLESTER's Avatar
Im not to sure if your asking if the f1 will work with stock heads and cam or what. but if thats what your asking then just save your money and get a p1-sc or a d1-sc. the f1 is designed for high flow applications and leaving stock heads and cams would be pointless, if thats not what your talkin about then just ignore this...
Old Oct 27, 2005 | 09:18 AM
Got Me SOM's Avatar
yea the heads will be a restriction and its worthless to put in a big blower if you aren't going to do the supporting mods to make the most out of it.
A p1 or D1 should make plenty of power for you.
Old Oct 27, 2005 | 09:30 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
You should have option 3 listed....
3- big turbo
With the turbo, the skylines will disappear very quickly into your rearview mirror.
Old Oct 27, 2005 | 10:27 PM
venom ws7's Avatar
molester yes that what i was asking will i dont have the money to get f1
heads and a good cam but thanks for the replay
got me som maybe i should think about p1 or D1 . what will you think it will dyno with p1 or d1 with full boltons stock heads and cam?
jz 97 ss 1500 i really thought about turbo setup but its really hot where i live
but really thanks guys you were a lot of help
Old Oct 28, 2005 | 05:47 PM
MOLESTER's Avatar
even with full boltons your really limited to your internals. without building your bottom end your limited to 500 to 600 whp. depending on your tune. if your wanting high horsepower build your bottom end first then the rest will come.
