Question for Mr. Raymer
Old Feb 8, 2003 | 02:43 PM
ProTour69's Avatar
Default Question for Mr. Raymer
Hello Rob, I have a couple of quick questions I was hoping you could answer, if you don't mind.
Well I'm building a pro-touring LS1 Powered 68 Camaro, and I would like to go Forced Induction one day. I have heard good things about you so I figured I'd inquire about your single Turbo setup for F-body's.
Heres my questions:
Would I or you be able to adapt your single turbo setup for 98-02 F-body's to my 68 Camaro, with some custom fabrication.
Would there be a major price difference.
Would you consider doing something like this.
Thank you in advance,
Ralph L
P.S. If you would rather me call you to discuss this instead of posting it, just let me know. Thanks very much!!!!
Old Feb 8, 2003 | 05:18 PM
BIGBOS's Avatar
Default Re: Question for Mr. Raymer
I would call him, he really isn't on this board much, I tried getting a hold of him like this once...didn't work.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 9, 2003 | 06:37 AM
Black LS1 T/A's Avatar
Moderator
He moderates the Forced Induction forum over on the "other" board. Try posting your question there if you want it discussed in a forum environment. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 9, 2003 | 09:40 PM
TchargedLS1TA's Avatar
From what I know the kit ws designed specifically from the ground up for late model fourth gen's only... The plumbing is made in such a way that it is meant to "snake" through all the smaller areas found inside the fourth gen.. The problem you would run into is the intercooler.. The first gen camaro has a radiator that mounts completely vertical while the LS1M kit is meant to mount the I/C at the same angle as in the fourth gen.. Also, the radiator shroud in the first gen may be mounted farther away from the engine, making the plumbing too short..
Hope some of this helps...
Old Feb 9, 2003 | 11:41 PM
zturbo's Avatar
See your from NY... Ever think of going to Kooks Custom headers or Turbo people? Two awesome shops and top notch work..
Steven
Old Feb 12, 2003 | 06:07 PM
ProTour69's Avatar
Hey Thanks alot for the two shops, their work looks great I'll definately be giving them a call in the future...you know of any other really good shops in NY?
Thanks,
Ralph
Old Feb 13, 2003 | 02:17 AM
zturbo's Avatar
No, none anywhere close to being in their league. Kooks is not cheap but does wicked work and builds lots of wicked cars. I would sit down with both shops and see what they can come up for ya though. If i think of any other shops i will give a shout but i just can't think of any others right now.
Steven
Old Feb 17, 2003 | 04:56 PM
Noyzee's Avatar
8 second mod
Hey Pro Tour, send me an email, I have some info you might like.It could help big time!!!
