Should I change cams for blower?
<strong> Id keep it. The only thing you might want to do is advance the cam a couple of degrees. Superchargers seem to like that. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Advance the timing? Even with 9lbs of boost? There should be detonation. I am not an expert but that is just what I have read.
Advancing the cam opens the exhaust valve sooner which can help exhaust scavenging. I mentiond it because your considering getting a cam with more exhaust duration. This would be less work and money than changing cams.
TT
Youre right about checking the cam specs. My mms cam supposed to have 5 degrees of advance ground into the cam. Probably wouldnt be good to advance it anymore.
I went from a 230/227 .591/.571 112lsa to
214/218 .540/.550 114lsa
How about lift? No one has really been talking about lift and I'm curious what you guys think are ideal numbers and why.
Is 114 lsa considered the best angle for blown applications? Someone mentioned something called icl, what's that?
Sorry for the questions, I'm new to cams guys. I want one that delivers maximum power and is able to spin up to 7200 RPM(I'd like to shift at 7K). Very interested to hear what you guys think.
Mike
<small>[ February 12, 2003, 02:56 PM: Message edited by: Blown Hawk ]</small>
My car should be done tomorrow, the heads came in, I should have updated dyno #'s tomorrow..
Going to be a big snow storm though, so I don't know if I'll take it home or not...
I haven't gotten a chance to drive it yet with the 214/218 .540/.550 114lsa 112icl
But the 230/227 .591/.571 112lsa cam I had had waaaaaaay to much over lap, and its reverse split...
I was told to keep the duration under 220 and the lift somewhat low, originally I wanted to go with a 226/228 .575/.585 114lsa for a blower cam, but learned more about them and decided to go with the smaller cam... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
