cam
Old Nov 1, 2005 | 07:49 PM
2000RedZ's Avatar
Default cam
i popsted in the internal section and i thought that id give it a try here too. i just got my ASA cam (226/236, .525/.525, 110) and now i want to go with an sts turbo kit, i was wondering if im gonna need a new cam. or will this one work. also if i do need a new cam which one, but i still want the killer lope that i have with this cam now, thanks
Old Nov 1, 2005 | 08:05 PM
snksknr's Avatar
Lsa of 110 is to low, I believe 114 is the minimum, use the search this has been discussed in past threads.
Old Nov 1, 2005 | 08:10 PM
ls1-ss's Avatar
I don't know a whole lot about turbos but I do know that cam will not work with a turbo, that 110 lsa is way to tight and will bleed off alot of boost and you will and up with alot of lag. You're gonna want a cam with at least 116 lsa and duration in the 220's for intake and exhaust to make the most from the turbo.
Old Nov 1, 2005 | 08:23 PM
Joel@
Guest
Posts: n/a
That cam is to big. You will need 114 or higher for a turbo app. Stay around 220's if you have stock heads etc. If you want a stock 02 and up zo6 cam will work fine to stay on the cheap side. If not get a aftermarket one.
Old Nov 1, 2005 | 11:51 PM
2000RedZ's Avatar
that's exactly what i thought thanks guys
Old Nov 2, 2005 | 05:06 AM
EPP's Avatar
EPP
We have installed a Comp camshaft that we had specially ground, on many of our customer's car that have forced induction. The spec's are 232/240 at .050 .595/.608 lift with a 115 lope separation. This cam works very well for us in forced induction applications, and yet it will still give the engine a lopey idle. This is the same camshaft profile we used in the twin turbo Corvette that we built earlier this year, and the STS turbo camaro SS. Bob
Old Nov 2, 2005 | 05:05 PM
618HAWK's Avatar
BoB
How would you rate this to the GT2-3???
Is your grind better off for a turbo vs blower.
Old Nov 3, 2005 | 10:15 AM
EPP's Avatar
EPP
The GT2-3 camshaft is much milder, and probably would give you more hp and tq through the low and mid ranges, however, the GT2-3 has no lope to it, what so ever... If you want a cam that has a great sounding lope to it that will also be blower friendly, than this cam fits the bill perfectly! Bob
(but i still want the killer lope that i have with this cam now)
Old Nov 3, 2005 | 10:24 AM
Mr_president's Avatar
does that cam with that high of lift take away from the turbo doing the work because i heard that if the lift is that high for a 346. you can damage the motor easier. however i am looking for a cam like that for my car as well! please let me know
