Need some advice with LS1 Supercharger
Sorry to be so winded, my question is this am I right in thinking that running at lower boast levels is better for my situation? What other components will I need to change out when I do a super charger at the 5-7 boost level with this kit? Will I have to change my clutch and drive shaft? What kind of Hp should I be expecting by just bolting it on and running it?
Thank you for your help, I really appreciate any input you might have. <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
<small>[ April 22, 2003, 03:58 PM: Message edited by: Pro Stock John ]</small>
1. I dynoed 501 at the wheels and 476 torque.
Now i have to save money to get my internals and heads to reduce the compression. Blown cars like lower compression as to the n20 cars which is higher. The ls1's can't handle more than 550 on the stock internals with boost due to heat and excessive wear. I didn't change mine yet( I should have) but haven't. It would be smart to atleast put a safty loop on it so you don't pogo stick it. The clutch i would change if stock.
It all depends on your mods and how much boost you run with the type of head unit you go with. There is the P1SC,D1SC,F1, all of these run different boost levels so it's up to you on exactly what you want to run with boost.
Thanks for the help <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Your best bet at this point is to just read, read, and read some more. Don't buy anything until you've researched it thoroughly. Try doing lots of searches and read as many posts as you can on the ATI ProCharger setup you want to run. There is a WEALTH of information on this board, you just have to dig a little.
Best wishes.
Randy.
I have the Vortech 9lb aftercooled kit on an otherwise stock motor. The kit has been on for 7,000 miles with absolutely no problems (except for lack of worthy opponents <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
The car has very few other mods, (none to the drivetrain) so I do NOT run it at the track. The first pass from a dig could waste the clutch or break something in the rear. I only "enjoy" the blower from a 30 MPH punch and have only street raced it from same. It is stupid fast by my standards and a very enjoyable car. The Vortech kit is complete with all the fuel system upgrades (T-rex pump, upgraded injectors) and they ship you the programmer for the computer. etc. I just had to get colder plugs.
The car is not a daily driver, but could be.
As for the other suggestions I see here, it depends just how fast you want to go. Mine is making plenty of power (probably 430 RWHP (505 flywheel), based on another stock car with same kit).
Any advice I could give you would depend heavily on how the car is going to be used. You can certainly drive a 5-7 psi car daily. If you want to race it, you'd better save up for a clutch and a rear end. Get a kit that is complete and get a professional install from a reputable shop.
The issue of reliability can be summed up in one word >> TUNING!
Mike M
http://www.forcefedperformance.com
We were pleased with the numbers since I'm running factory everything (except injectors and cat-back). I was tempted to try the nitrous as well, but we kept our attention on the supercharger tune. We also did it on 91 octane pump gas since I didn't want to mess with mixing fuel.
We couldn't run more than 17 degrees timing at WOT, or the knock retard would kick in. But I'd rather know I'm clean than try to eak out a few more HP. I can't hook this up now, so why bother?!
Mike M
Look at it this way, you are forcing air through a straw so it's restricted as if you are forcing air through a hose which is bigger in diameter which means less work for the air to get fed through it.Getting heads would benefit in easier access for air to flow and lower compression. This isn't a have to do thing right away with 5-7 LBS of boost.
With what i see you have done to you're car now, you will have no problem running even 8PSI. You're motor can handle it with the charger and mods but the next thing if you get the charger should be heads and internals so you have something to back up all that power. you're compression will change very little with the blower( go up) but not enough to worry about.
The main thing to worry about will be opening all that restriction up with heads, since you already have the intake ETC. When I get heads and internals for my car I will be around 9.1:1. I would'nt worry about the heads and compression yet too much unless you have the money to spend.
Now for folks like me that went with the D-1SC, we might have some problems with visual. The serial number on that unit will not get a response out of ATI that "Yep, it's legal". We'll have to find a shop that will look at the documentation, see that it references a carb number, and then not notice that it is stamped "D" instead of "P". Basically, find someone that won't call ATI!
Mike M
