Some STS graphs and a 2bar tune on a 98?!?!?!
Below you will find 2 graphs. The comparo is between a bone stock 02 TA at 9psi with FMIC and meth and a 98 Camaro with Syngery 370ci motor on 9psi FMIC, no meth with a custom Synergy 2bar tune Yes 2 bar on a 98. Now the 98 is not fully done, this was their first pass at it. Both cars have the GT67 turbo. The TA is done for now, the Camaro will see alot more boost once the alky is flowing.
So like any turbo setup, it's all in the combo. As you will see these buggers can spool up just fine and make some nice power as well all already know.
And 98 folks, if your interested in a custom 2bar tune give Rick a call!
Also please note even though the graph is labled flywheel this is power at the axle. The dynapak gives the option to convert to flywheel if you wish. I guess Rick should just learn to rename that graph
Enjoy!
Synergy 370 vs Stock 346
Boost comparo
the tuning is all Rick. a few years ago I could show him a trick or two but now he is the man when it comes to tuning.
he is constantly educating himself and that dynapak is just too f'n sweet to help dial in a car.
Anyway, those are some pretty good numbers to say the least. How much boost are they going to push? What's the combo on the 370 (heads, compression, etc)?
I believe it's a 9:1 motor.
All the heads/cam/etc... specs, that I don't know. I didn't ask.
I know the owner thinks he wants to shoot for 700, so I know a turbo upgrade will be in his future if that holds.
J
the tuning is done is 2 bar off a stock 98PCM. Yes, it can be done and it works well. I am helping frcefed98 with his also.
Rick
