How much boost?
dont get greedy with the boost or youll end up with more paper weights6.0 heads are cheap, especialy when you consider you might junk your motor, gaskets can drop it a few compression points as well (maybe .3 ?) just do an CR calculator online and find out what what changes to the engine will do and evaluate which ones you can afford
