The new setup!
Old Dec 6, 2005 | 12:29 PM
Forced370GTO's Avatar
Default The new setup!
Hi everyone, i have just made my final decisions regarding my setup;
370ci low compression Iron shortblock
12-14psi From D1SC + intercooler
patriot stage 3 lq9 heads
237/242 .603/.609 115LSA cam
Stock ls6 intake
LT headers + true dual 3 in exhaust
93 octane tune
What should i expect as far as power at the rear?
What size injectors should i purchase?
Any recommendations regarding anything?
Thankyou for your time!
Old Dec 6, 2005 | 01:27 PM
NA$TY-TA's Avatar
Stock ls6 intake
93 octane tune
as far as power id say around 600rwhp....
Now the injectors.... nothing but Motron 60#ers...
What FMIC??
Kyle
Old Dec 6, 2005 | 02:41 PM
my buddy is seeing 600rwhp with no heads and only 10 psi on a 224/224 cam, i was thinking low 700s
Old Dec 6, 2005 | 02:50 PM
Turbo LS1 SS's Avatar
600rw with stock heads with 10psi seems a little steep to say the least....you should be about 650rw tho....that cam is pretty big imo....but should be badass nonetheless!
Old Dec 6, 2005 | 03:00 PM
CHRISPY's Avatar
I'd probably go a little smaller on the cam. With a 224/224 114LSA cam and 15-17#'s boost you should have 650RWHP on pump gas and great driveability. (If compression is at 8.0:1 or thereabouts and you have an awesome tuner)
Cheers,
Chris
Old Dec 6, 2005 | 04:41 PM
Got Me SOM's Avatar
aye yaye yaye, go with an aluminum ls2 block that Goat is heavy enough as it is. plus your underhood temps are gonna get real hot with an iron block. iat's are bad enough as it is with aluminum blocks with the computer pulling timing.
cam is WAY too big and will idle like ****.
Old Dec 6, 2005 | 05:24 PM
can anybody help with a good cam for 14psi? i want a good lopy sound and awesome power.
Old Dec 6, 2005 | 05:45 PM
Got Me SOM's Avatar
224/230 115 plenty lopey.
Old Dec 6, 2005 | 06:33 PM
how much power will the 60lb injectors support
