Turbo/component selection 347...
Old Dec 12, 2005 | 10:15 PM
Phil99vette's Avatar
7 Second Club
Default Turbo/component selection 347...
Here's the combo....
Built 347
ET heads 11 degree 225cc
Cam who knows 230/230 116lsa
~9.0:1
Tube style manifolds 1.75" SS with merge collector
twin 3" downpipes
twin PT-61mm turbos .68 or .81????
3" pipes to the turbos
3" pipes to the IC
4" pipe from the IC to the TB
90mm TB
twin 38 wastegates externally vented 1.5" dump tubes
twin BOV's on IC
Spearco IC, looking for 10 X 30 x 4.5 flowing top to bottom
Old Dec 12, 2005 | 10:26 PM
qqwqeqwrqwqtq's Avatar
What is your hp goal?
Old Dec 12, 2005 | 11:45 PM
StoleIt's Avatar
NKAWTG...N
76 GTS for high hp
70 for lesser lag and a decent spool but mid-ish hp.
On a side note: I hate a t76 (non-GTS) and it is spooled around 3k. No complaints from me.
Old Dec 13, 2005 | 02:44 AM
black98ws6ta's Avatar
Built 347
~9.0:1
twin 3" downpipes
3" pipes to the IC
90mm TB
twin BOV's on IC
I would think .68 hotsides for a 347...
Old Dec 13, 2005 | 05:31 AM
V8_DSM_V8again's Avatar
I would drop compression ratio DOWN to about 8.0....
The T61's like running high boost..
At 8.0 CR you can run more boost and timing....
The .68 T4 turbine housing should be alright...
The 3" turbo inlet pipe is a good Idea...
However I would on the outlet side keep it small.. Basically what ever size the outlet is ~match it... Like on a 2" outlet compressor cover I'll use 2.25" piping max...
Coming out of the IC use a 3.5" pipe because 90mm~3.5 inches.
Smooth transisitions in diameter..... Also minimize the piping volume ... Like a head ports volume... Try to pick locations to mount and route things that keep the IC pipes as short and as straight as possible.
You were giving up alot of efficiency and spool with the other specs.
Old Dec 13, 2005 | 07:14 AM
hellbents10's Avatar
LS1Tech Sponsor
I would go with the .68 hot sides. Should go like whoa. 3" down pipes yes. 1.5 times the size of the ext. wheel, so 3" is appropriate. 3" to the intercooler and 4" to the tb would be exactly what I would do. Two turbosamrt 38mm units would work great.
Old Dec 13, 2005 | 07:27 AM
2" outlet turbo 2-2.25"
2.5" outlet turbo 2.5"
I still say 3.5" to the TB... A good molded silicone coupler will make the connection between the 3.5" and the outer diameter of the throttle body with minimal turbulence or uneccessary increases in area.
You dont want to choke it and you dont want to go so big you loose velocity and increase the spool point..
I have done a few FMIC's... Those rules of thumb work wonders.
Air to water has been the most wicked not just because of potential efficiency but because of much faster spool due to drastically reduced pipe length and much fewer bends..
Old Dec 13, 2005 | 06:02 PM
7 Second Club
Sounds good, so 2.25" piping to the IC from each turbo and 3.5" to the TB with a 3.5" to 4" silicone reducer. 3" pipes from the filters to the turbos. Each side will get 38mm wastegates.
Phil
Old Dec 13, 2005 | 06:06 PM
Yep...
What are you doing for a BOV...
I'd recomend either TIAL or Turbosmart for either the BOV or the gatesreally...
Old Dec 13, 2005 | 08:40 PM
sr71's Avatar
go with .68 ar's, Phil. mine make full boost at 3800.
Old Dec 13, 2005 | 08:53 PM
Its good advice from a well engineered homebuilt car...
SR71...
See what I'm up to this time?
I'm using twin 61's but with the T350 wheel and a .63 A/R T3 side...
I'm giving up about 50hp or so per turbo but given the application its worth it.
The idea is for a quick spool low & mid rpm truck motor..
Imagine 1k hp & Tq combined with 28" Front and 38" rear suspension travel...
Old Dec 14, 2005 | 09:02 AM
FastKat's Avatar
Sweet, that sounds perfect for a street car...
Old Dec 15, 2005 | 07:25 AM
EVIL's Avatar
phil, what are you up to now?
Old Dec 15, 2005 | 08:16 AM
Hawkcmc's Avatar
[QUOTE=V8_DSM_V8again]I would drop compression ratio DOWN to about 8.0....
[QUOTE]
Doesnt 8.0 seem a tad low for a street car? Better to keep it higher so that your not bogging until you get into boost? Thats just what I was told.
CMC
Old Dec 15, 2005 | 09:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
An 11:1 346ci could make 425rwhp easily.
So a 8:1 346ci could make that minus say 3-4% for each point in compression drop.
So if I use 3.5, that would mean that a 346ci could be making say 380rwhp.
I went 11.6 in 2000 with 375rwhp, with stock suspension and a small converter.
Trust me, 8:1 (I'm around there), has no bog. What's bog when you have a 4500 converter, and make over 700rwhp by 6000 rpms.
Old Dec 15, 2005 | 12:21 PM
LTLHOMER's Avatar
What are your goals? And do you want to run pump gas? Stuff like that will probably help out.
Old Dec 15, 2005 | 12:36 PM
7 Second Club
Low boost gets pump gas 12-15psi, high boost gets race fuel 17-25psi. Breaking records is what I like to do...
Phil
Old Dec 15, 2005 | 04:41 PM
LTLHOMER's Avatar
I like breaking hearts not records...what kinda record you going for?
Old Dec 15, 2005 | 06:27 PM
7 Second Club
Who knows, I have never seen a 8 second 346 c5 so I guess thats a good place to start.
Phil
Old Dec 15, 2005 | 07:51 PM
TTSSZ's Avatar
Phil
Cartek 2002 TT 346ci vette
8.49 @ 156 MPH
