Pretty head repair
Old Dec 18, 2005 | 07:41 PM
parish8's Avatar
single digit dreamer
Default Pretty head repair
looks sweet. , these are afr225's
old
fixed
Old Dec 18, 2005 | 07:43 PM
V8_DSM_V8again's Avatar
Leaned out?
Old Dec 18, 2005 | 08:23 PM
parish8's Avatar
Originally Posted by V8_DSM_V8again
Leaned out?
yeah, a little. i was running 20psi and a 100shot and my fueling went to around 12.0-1. that was about 1/2 a point plus leaner than i was shooting for, my fault entirely.
my 1/8th mph and weight sugest this was around 1140rwhp
stupid number 7 too
Old Dec 18, 2005 | 08:27 PM
Well I'm looking for similar #s for a off road rig..
One thing I learned on other turbo cars is how awesome a stand alone with WB02 feedback is.
Sure helps out in avoiding things like that...
Old Dec 18, 2005 | 08:29 PM
parish8's Avatar
yeah, i have that option. i had it shut off, not sure why. i kind of wanted to get my tune close before i turned that on.
Old Dec 18, 2005 | 08:33 PM
I start out rich and work back..
As I get close on my own I turn the feedback on.. That way it either pulls fuel or runs rich... Lets say I'm almost 1/4 point too rich I start like 1pt too rich the first time... Any way from 1/4pt it can get it on by pulling fuel...
Old Dec 18, 2005 | 08:51 PM
parish8's Avatar
yeah me too, that was my goal. this was the first time i hit it with the 100shot and i added what i thought was a lot of fuel. i should have made a partial pass to check it but i wanted to get my 9sec run out of the way. i think i will just get a bigger turbo and stick with the boost from now on.
Old Dec 18, 2005 | 08:55 PM
98turbls1's Avatar
Wow!!! That's awesome work to get those back in shape....Who did your work?? Those are some expensive heads to just throw away....
Well it depends on what you have for injectors...
I dont like N20 fuel jets or bars.. Atomizies like crap..
If you have big enough injectors and a smart EMS... It can do full N2O fuel enrichment and control the N20 system..
I'm used to AEM... Have'nt tuned a BS3 yet..
100shot should'nt be a big problem....
Old Dec 18, 2005 | 09:20 PM
parish8's Avatar
a local guy fixed them up for me and yeah he did a nice job. he only charged me $325 and for that he fixed the one head, suraced both. valve job on both, checked and shimed the springs. i am happy.
i have big injectors and am shooting a dry shot. i just didn't program in quite enough fuel. like i said, my fault. next time i will do some partial runs and see where it goes before i try a full run.
Old Dec 18, 2005 | 09:26 PM
Who did the 4L80E...
I have done transmissions before.. TH350 and TH400 series and mopars...
I'm thinking reverse manual valve body, Art Carr gate shifter.. etc...
Old Dec 18, 2005 | 09:48 PM
parish8's Avatar
it's in my sig. other than a broken inputshaft this tranny has been awesum. i have many ~1000rwhp runs on it.
Old Dec 18, 2005 | 09:49 PM
cool...
soo far the cheapest I have seen the v-body is just under $300
While I probably would'nt buy a full trans from anyone just components. http://www.transmissioncenter.net/4L80E.htm
Is about $100 cheaper on the 300m input shaft....
Other than that your trans shop looks like a good one...
Old Dec 18, 2005 | 09:51 PM
98turbls1's Avatar
1000rwhp truck!!!! Holy crap can you say SLEEPER!!! Dude that is freaking awesome...
Old Dec 18, 2005 | 10:07 PM
I was'nt sure if I would need the upgraded input shaft sine the 4l80E is so much bigger than a TH400... I know I'll get one now...
I'll also need a converter with a really good lock up clutch.
If there is anything you could have done differently or seen others skip that they should'nt have on the trans let me know..
Old Dec 18, 2005 | 10:16 PM
parish8's Avatar
the one thing i can say is dont lock it thru the shifts. that is when my input shaft broke. i lock it up right after the 2-3 shift now.
i am running a PI ~2800 10.5" tripple disk. seems to be holding up great.
Old Dec 18, 2005 | 10:28 PM
Did you put a stocker in or a upgrade after the break,,
I'm going to be acting like these guys....
http://video.off-road.com/videos/back1.mov
So I think I'll run the upgraded shaft..
Maybe even a upgraded output..
Have a link to PI ?
I'd prefer a slightly lower stall...
Old Dec 18, 2005 | 10:46 PM
parish8's Avatar
it is a cryo treated shaft now. i am kind of chucks(at finishlinetrans.com) test dummy. there is some kind of billet shaft out there but chuck wanted to see if i can break this one. if i can't break it then he kind of gets a feel for when to recomend the billet shaft to people.
Old Dec 18, 2005 | 10:54 PM
I saw the 300M (billet) shaft on their site...
I have never seen a 300M output... I'll have to ask how much to get my output cryo treated.... I have a friend at a local salvage place looking for a 2002 and newer 4L85E... Has 5 pinion planetaries...
Oh well... nice truck.. What rear diff? I am going to run trutracs at both ends..
I am still trying to figure out a T-case.. Might be a highly modified NP242...
Old Dec 18, 2005 | 11:39 PM
whynot's Avatar
they did an amazing job, are those the heads from the video with the fireballs under the truck?
