how much psi can I run on stock bottom
sts turbo with upgraded 67mm turbo and a ls6 intake, I want a set of headers no cats and a set of heads like the 6.0 heads.what boost can I run with this set up? what else should I get I want to leave the bottom stock for now and I would like 525 at wheels I have the elky kit too
I am right at the limit but oh well if something brakes it will give me the reason to rebuild and upgrade.
Boost is a horrible way to measure things, it's just restriction. Don't detonate or go lean and the amount of boost is irrealevant.
The general consensus is that 8 psi with a good tune is reliable. The key being a good tune.
