Is this for real?
Old Dec 21, 2005 | 05:55 PM
SS MPSTR's Avatar
Default Is this for real?
http://www.fbodyaddict.com/thread-vi...21799&posts=18
I'm a doubter....but what do I know?
Old Dec 21, 2005 | 06:02 PM
y2khawk's Avatar
Enough to know better
Me thinks he missed a factor of 2 somewhere in his "math"
Old Dec 21, 2005 | 06:06 PM
SS MPSTR's Avatar
I was being facetious, and I want whatever he's smokin'. The numbers might be plausible if multiplied by 0.48 or 0.52.
Old Dec 21, 2005 | 06:16 PM
98turbls1's Avatar
that guy is LOST!!! pretty humorous though...He couldn't figure out why the whole world wouldn't agree with him that it was going to be over 1000fwhp...
Old Dec 21, 2005 | 06:17 PM
~RedLineLs1~'s Avatar
I wish it were that easy to make 1000hp. 12 lbs and a 50 shot? Hells yes!
Old Dec 21, 2005 | 06:18 PM
CamTom12's Avatar
Hey, I've done the work and he's totally correct.
Show me your math.
lol...
Old Dec 21, 2005 | 06:20 PM
RyanJ's Avatar
SSU Moderator
moron.
HellRaiser's Avatar
WOW maybe I'll get that guy to work on my car? I could always use 1000hp
Old Dec 22, 2005 | 03:19 AM
onephatZ28's Avatar
Hey guy's I am the guy who got the whole sts turbo question started. I just want to let you know that this math doesn't apply to real life. I just had a question to see your opinion of horsepower numbers using the equations from horsepower manufacturer's. I would be the happiest guy on Earth if the car makes 500+ at the wheels. The car right now runs 12.3, if I can get the in low elevens I would be quite content. once again the 1,122 horsepower was a question and not a statement. I would appreciate it if you know of anyone running the sts turbo, please send me the numbers of the horsepower the car is making. The whole reason why I did this is because people don't read what I post and I just wanted to argue because I had the numbers from the manufactures that can back me up. Even though we all know they are not as realistic as we would like them to be.
Old Dec 22, 2005 | 03:22 AM
onephatZ28's Avatar
Just for fun, if you would like to see the mathematical formula I used it is at the begginning of the second page on that post. It's funny because it does add up to 1,122 horsepower before nitrous.
Old Dec 22, 2005 | 03:31 AM
V8_DSM_V8again's Avatar
a mounted... oops rear mounted turbo is'nt going to make that kind of power.
Its too inefficient..
The amount of energy the turbine absorbs way back there is'nt as much and the system has to move the air all the way up front on the cold side..
Twins with a great IC, good cam, good head etc could hit that 25psi and up...
Old Dec 22, 2005 | 05:02 AM
HellRaiser's Avatar
Search for PurEvl He made some nice numbers with his STS kit. I think theres a couple GTO's that are running low 10's with it to but not to sure how much power they are making.
Old Dec 22, 2005 | 05:10 AM
EPP's Avatar
EPP
Smile
http://www.exoticperformanceplus.com...Car.php?car=32
Check this STS Camaro SS out. Bob
Old Dec 22, 2005 | 09:36 AM
Ryan K's Avatar
Pathological Modifier
The other MYTH is that Turbos take no power to make power...
Its called back pressure and Turbos make a hell of a lot of it.
Ryan
Old Dec 22, 2005 | 09:46 AM
SS MPSTR's Avatar
Nice back-pedaling
Old Dec 22, 2005 | 10:08 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
I will say this, efficiency, efficiency and efficiency....btw did I say efficiency. Compressor maps are shewed heavly when mounted in the rear. And if you go by what STS writes on their website, then the world is still flat.
Also turbos require a good bit of power to turn. We have worked with some turbo companies to work out rough equations for this as well as our own findings on a turbo test stand.....
BTW, a 408ci engine, revving to 6500rpms, running a S-trim turbine (2.96 E/ 3.200 I), 76mm compressor wheel at ~50% efficiency (which is approx. the efficiency where a 76GTS would be running on a 408 at @20psi), would require/cost ~ 163.32hp. You would be suprised how much hp people give up on this site and others by running to small a turbo/turbine...
Old Dec 22, 2005 | 12:03 PM
hellbents10's Avatar
LS1Tech Sponsor
Ya, but I want max boost by 2000rpm lol. I hear that stuff way to much. If you do not have lag then you do not have a big enough hair dryer.
Old Dec 22, 2005 | 12:55 PM
SINISTER's Avatar
hp=****
all about the et's!!!
Old Dec 22, 2005 | 01:06 PM
onephatZ28's Avatar
Hey guys,
thanks for being cool and seeing this for what is.
The other forum doesn't really write back much so I think you adopted this baby.
Seriously though, what is up with STS advertising their product as taking zero horsepower to operate. You can read their exact quote in supercharger vs. turbochager page on their website.
The temerity of such companies that would advertise under a false pretense just make a buck. It's already hard enough for double digit I.Q.'s such as myself to focus on a positive integer less than two.
Look guys, we're ambassadors to racing and therefore should make known when malfeasance is being employed to deceptively and fraudulently sell a product. This is only if the website is in fact incorrect and doing so knowingly. Let's advodcate for social justice so we all are apprised of what each modification really does.
Respectfully,
Chagrined STS AGNOSTIC!
Old Dec 22, 2005 | 05:22 PM
SS MPSTR's Avatar
Hey guys,
Respectfully,
Put the thesaurus down and slowly back away....
