Procharger P1 on a stroker #'s????
Old Dec 22, 2005 | 12:31 AM
b727pic's Avatar
Default Procharger P1 on a stroker #'s????
Having to go through my bottom end on my 8,000 mile GTO LS1
searching for options...pretty much figured all that out. What I would like to know is, with the P1 being pretty limited, has anyone got a stroker 383,402,408 with high flow heads, full exhaust and a P1??? curious as to what boost you are able to maintain???
Old Dec 22, 2005 | 01:28 AM
Ed Blown Vert's Avatar
Here is my situation. So far 10# is all I can get out of it right now.
https://ls1tech.com/forums/forced-induction/395505-sdce-belt-slip.html
Old Dec 22, 2005 | 04:39 AM
EPP's Avatar
EPP
Question
Ron, what did you find out with the engine? Bob
Old Dec 22, 2005 | 07:53 AM
Cyborg's Avatar
4 pounds with a 4 inch blower pulley. I will soon be switching to a 3.4 inch pulley and if you want I'll report back what boost level is achieved. Set-up is a 402 w/ AFR 225's. FYI, at 4 pounds I'm at 557 SAE RWHP on pump gas.
Old Dec 22, 2005 | 10:26 AM
b727pic's Avatar
Hey Bob,
The more I thought about the possibility of a broken ring land galling up my cylinder wall the less prudent I thought it was to drive it any more. I pulled the head yesterday...I am somewhat dissapointed because there is nothing obvious there is a very faint vertical line on the cyl wall but I can't feel it and it wont catch a finger nail.... the head looks good. As for the Head Gasket....who knows, I did not see any signs of blow by.
So I am very confused....but at this point she is not going back together without forged internals....the only question is how wild do I get. hence this post, with the limits of the P1 I don't want to spend and extra $2500.00 on a good set of heads, only to wind up with 8-9 PSI out of the blower....I may be wrong but I am thinking I gain more HP keeping my stock heads (or something similar) and running 12-13 PSI....what is your opinion??
Old Dec 22, 2005 | 10:31 AM
b727pic's Avatar
Cyborg: I am very interested in what you find out...on a 347 CI with an EDC cam, JBA shorties, and a 3.6 pulley I am right at 10 PSI @6500. I am assuming with a 3.4 that should put me at around 12 PSI.
just with the JBA install I lost 1 psi, I imagine any head flowing anywhere near the 300CFM mark as compared with stock is going to have devastating effects on my boost
Old Dec 22, 2005 | 10:32 AM
b727pic's Avatar
https://ls1tech.com/forums/showthread.php?t=395505
thanks, this is exactly the info I need to make an informed decision.
Old Dec 22, 2005 | 10:50 AM
Cyborg's Avatar
Remember a higher flowing head or higher flowing setup in general may eat away some boost but increase your power and torque...it's not necessarily a bad thing that you're running lower boost if your power & torque are going up!
Old Dec 22, 2005 | 11:49 AM
b727pic's Avatar
I agree..but here is the million $$ question
If motor A is generating 400HP @zero boost, then crank in 12 PSI motor should be around 700 HP
If motor B is generaing 450HP @ zero boost, then add in 7 PSI motor estimated power is around 650
Looks to me as if Motor A is the better scenario for power, motor B will probably last longer....but you are leaving some HP on the table.
The problem is the ATI P1 is limited when our engines start pumping more air through them. Even the D1sc is not gonna support 18 PSI on a big cube good flowing motor.
While I enjoy all the trick stuff just as much as the next guy...ie cool heads, big cubes etc..... it looks like my best power choice is Motor A which strangely enough is the least expensive option
Old Dec 22, 2005 | 01:04 PM
EPP's Avatar
EPP
Hmm, it makes sense. Since you are stuck with the P-1SC, (for now...) you might as well keep the stock cubes and just add better rods and pistons. You could keep your stock heads and reduce the compression ratio down to a more boost friendly 9.5/1 compression ratio, which would help with the 91 octane fuel in your area. Bob
Old Dec 23, 2005 | 11:30 PM
TrakDay's Avatar
Hell... I am going to be looking for 13-15psi on the 408/heads/cam combo I am working on putting together! I already know of a local Trans Am putting down over 750RWHP on a D1 with a very similar setup to what I am planning!
Swap the P1 unit for the D1!!!
Old Dec 24, 2005 | 12:05 AM
b727pic's Avatar
Hey trak
The D1 is only flowing 200cfm more than the P1, I think "IF" you get your PSI goals on the 408 with good flowing heads you will be pretty much where I am now......maxing the blower RPM and out of options....
I toyed with the D1 internals swap, but with a plan of better flowing heads I will need even more than the D1.......I am currently working on that plan as we speak
Old Dec 24, 2005 | 04:59 AM
EPP's Avatar
EPP
Talking
Hey trak
Man, you get up early Ron! lol Bob
Old Dec 24, 2005 | 10:35 AM
b727pic's Avatar
Naw just up late....
We are having a very BRADY Christmas around my house. Somehow after 25 years it was our "turn" to host the annual family gathering....Looks more like a Boy / Girl scout camp out than anything else!! Lol.
Merry Christmas and wishing everyone more HP in the New Year!!
Old Dec 24, 2005 | 02:52 PM
TrakDay's Avatar
Yeah... have you toyed with the option of an F1R yet!? From my understanding the P1 is good for 600-650rwhp...the D1 is good for 725-800rwhp...
With my planned setup I am hoping to be in the low-mid 700s!
Old Dec 24, 2005 | 03:58 PM
b727pic's Avatar
Youre getting warmer
Old Dec 24, 2005 | 05:37 PM
TrakDay's Avatar
Well... you need to let me know! and get some dimensions! It is going to be hell getting anything bigger than the D1 in our engine bay!
Old Dec 24, 2005 | 06:17 PM
b727pic's Avatar
Hole saws, Hack saws, files, hammers, some scrap 16 ga, a welder, a little primer and paint.........anything is possible
You did see my crash bar mod right?????
