Engine test fit
Old Jan 5, 2006 | 07:23 AM
Lasershop's Avatar
Originally Posted by smokinHawk
huh, more info on how to anodize, do you have a link or something, thats interesting.
Love to start one. My DIY anodizing is second to none. Been doing this kind of stuff a long time. Was going to do a thread in "tools" but honestly I thought it would just get lost in there. Been garage polishing for 35 years. Except for the anodize tank (diluted battery acid), my other plating supplies are all water based. Commercial plating is cyanide based. Nasty ****. Copper/nickel/chrome. Anyone can do it but its like painting..... only as good as the prep. You could set up a 5 gal. anodizing system for less than $100.00 including dye (not including a cheap battery charger).
Old Jan 5, 2006 | 07:32 AM
Tiago's Avatar
cleanest setup EVER
Old Jan 5, 2006 | 09:08 AM
FastKat's Avatar
You should definitely start an anodizing thread... either in tools or the appearance/detailing section.
Old Jan 5, 2006 | 09:02 PM
ABeasst's Avatar
here's a link to anodizing http://www.focuser.com/atm/anodize/anodize.html
Old Jan 5, 2006 | 10:24 PM
boonesjgsilverado's Avatar
Brought the motor home. First time the chassis and motor have met each other. Everthing seems to fit far better than I had hoped. Motor will go back to the shop next week to begin construction of the intake. Had to get measurements for downpipes and just see where I am at with the project.
Who built your headers? What size BOV valve and brand are you running?
what turbos?
thanks
Old Jan 6, 2006 | 08:08 AM
Gunnar@Patriot's Avatar
That setup is KILLER !! Looks great !!
Old Jan 6, 2006 | 10:14 AM
Lasershop's Avatar
Thanks Gunnar. Proud of my Patriots. Ought to make a few HP.
Old Jan 6, 2006 | 10:18 AM
Lasershop's Avatar
what turbos?
thanks
Home-made headers. Stainlessheaders.com collectors. Wategates are Tial 44mm. Probably go with the Tial 50mm BOV when that time comes.
Old Jan 6, 2006 | 10:29 AM
looks great you do excellant work.
Old Jan 6, 2006 | 11:55 AM
BLk01SS's Avatar
That's badass!!!!!!!!!!!!!
Old Jan 7, 2006 | 06:09 PM
FastKat's Avatar
1) are you worried about the headers and exhaust manifolds being too close to the hood for heat reasons? Won't that discolor the paint on the hood?
2) What's going on with the alternator there... is that it behind the power steering pump?
Old Jan 7, 2006 | 06:36 PM
  #32
2toneblown's Avatar
what power steering pulley is that?
Old Jan 7, 2006 | 07:56 PM
  #33
solobaric's Avatar
That is a work of art man! Incredible work man! Could you provide some basic specs on your motor? CI??
Old Jan 7, 2006 | 08:44 PM
  #34
Lasershop's Avatar
Have not made the heat sheilds yet. Carbon fiber 4" cowl hood. Alt is way back there.
Old Jan 7, 2006 | 08:46 PM
  #35
Lasershop's Avatar
Got it from Ecklers Item# 48507. Hard to get. $100 bucks.
Old Jan 7, 2006 | 09:08 PM
  #36
Lasershop's Avatar
Only thing original is the block and crank. Those two items have about 1000 or so in machine work and balancing. Rest is the usual forged/cam/valvetrain/heads.
Old Jan 8, 2006 | 01:00 AM
  #37
Whistler's Avatar
Sawzall and Welder Mod
Good work bro. Very clean.
Old Jan 8, 2006 | 02:35 PM
  #38
FastKat's Avatar
So are you going to put the heat shields over the headers too? It'd be a shame to hide all that nice work! I see a lot of people run the headers/manifolds low, but not too many run them up high. Even if you have two or three inches between the hood and the turbine, I could still imagine you could have some heat issues. Just curious because I want to keep the manifolds and turbines up high on my setup and just want some more thoughts on it.
Also, how did you get the alternator way back there? It doesn't look like it's on the main accessory belt pulley.... what did you do to make that work? Just curious because I will prob have to relocate my power steering pump on my Fbody pullout if I run my manifolds/turbines up high too.
Thanks! -Dave
Old Jan 8, 2006 | 07:23 PM
  #39
Lasershop's Avatar
Thanks! -Dave
This is the alternator thread https://ls1tech.com/forums/showthrea...ight=alternate
Far as heat sheilds, I can lasercut thin stainless so I will do some kind of nice looking pattern. Was even thinking flames like the Audiobahn amps...... but thats a bit much.
  #40
Lasershop's Avatar
Thanks! -Dave
Far as heat sheilds, I can lasercut thin stainless so I will do some kind of nice looking pattern. Was even thinking flames like the Audiobahn amps...... but thats a bit much. Once again, my hood is a lot taller than stock.
