Help choosing new turbo...
Complete list of mods is forged 370 iron block, 9:1 compression, stock heads, 02+ LS6 cam, meth injection, RAM HD clutch, 42lb injectors (60s on the way), HPTuners, STS kit @ 9psi.
Here's a dyno chart from my 9psi pull.... as you can see the turbo is dying after 5000...
EDIT: Perhaps I should be looking into an even larger turbo like a 76GTS?
What you really need is the compressor map for the turbos your looking at and either have someone or yourself (isnt hard)plot your car on a map. so you know ideally what your looking for..
The stock turbo is a Garrett TO4E 60-1 with a .81 A/R.
I haven't read a compressor map in a while... my buddy needs to give me back my copy of Maximum Boost.. haha.
Does the T-60 have a P-trim housing? If so, you could just swap housings. If not, you could probably save a little money buying an on-center .81 a/r housing off ebay for $40-$60 . The MP T-70 has a P-trim exhaust just search for on-center, P-trim, .81 a/r exhaust housing.
Later,
Dave
Any other thoughts?
Thanks
From the other thread.......
He is out of turbo......... boost is just a number and ..... its how much air is flowing..... all boost is, ia a restrictin to flow..... thats why when aftermrket heads are added the boost will drop but the power will stay about the same.......
Big difference when trying to boost a 120ci civic..... we have 4 more cylinders and twice the area to fill with air..........
Go with the 76mm turbo and .81..... but to be sure id give Jose at Forced Inductions a call.
Kyle
