Roofer Dave's car back from paint (56K warning)
Old 02-23-2006, 12:34 PM
  #461
LS1TECH Sponsor
Kevin@W2W's Avatar
the lines off of the spacer are assorted vacuum and boost reference lines. With the manifold pressure this methods allows good connections without blowing lines off.
Most back halved or tube chassis cars locate the driver in that position for many reasons including sitting lower in the car, ability to get in and out considering the funny car cage addition, placement of weight, and that cool chicano low rider look. :Jest:
Chassis should cert 25.2 and the only factory unibody left on the car is in the engine compartment. Other than that it is pretty much all tube chassis up to the termination point just beyond the front wheels and I do not believe the car will recieve carpet.
The oil pan is a cast piece from ARE that we use on all of our dry system builds. It also adds a little strength to the block.
More pics as soon as I can guys and thanks once again for the kind words.
Old 02-23-2006, 12:41 PM
  #462
Keith's Avatar
Originally Posted by Louis
Its an ARE drysump pan, hence reason it looks odd. I would assume 5 stage, 3 on the pan, one non-pan scavenge which, can be a variety of things, and one pressure.
Could the non-pan scavenge be used as a vacuum pump? Like off of one valvecover?
Old 02-23-2006, 12:46 PM
  #463
Camaroholic's Avatar
The attention to the little details is just amazing.
But it's never gonna start unless you bolt the starter to the motor.
Old 02-23-2006, 02:42 PM
  #464
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
The car isn't getting any carpet.The floor looks too good to cover up.
The seat was moved back for a couple reason's.
With the halo around the driver there wouldn't be much room for me to get out of the car if left in the stock location.
I'm 6'2" and wanted to put my 230-240 lbs as far back in the car as possible for weight distribution purposes.
We thought it would be smart too put me as far back as possible while still being able to reach the pedals.The custom steering column helped with this also.
I appreciate the kind word's and want to emphasis Kurt and the staff at W2W came up with the plan for this car.I'm just paying the bill.
Dry sump is a Dailey 5 stage.
Old 02-23-2006, 03:42 PM
  #465
kp
kp's Avatar
Car looks even better in person, wasnt so sure on the color (not a big yellow fan) but its going to look awesome in the sunlight. Seeing the car in person you can really appreciate the craftsmanship involved and attention to detail.
Old 02-23-2006, 05:23 PM
  #466
LTLHOMER's Avatar
Originally Posted by RyanJ
What are the switches for under the rear bumper?
I'm guessing they are for the crew to push for the 'timer enable' function (or something equivalent) on the bs3 which is what is triggered in order for the data-loggers to start acquiring data...you will see a lot of cars at this level with a crew guy that looks like he's holding on to the car and that's exactly what he's doing...no use filling up your data sheet with a bunch of useless time while waiting to stage and what not...that and I think you only get 30 seconds of data at the highest transfer rate so you could run out before you even staged if you didn't have someone doing this for you...and the drivers themselves usually don't do it so they can focus on staging and cutting a good light...no sense having them do extra things when they can be done externally much easier and reliably...
I could be wrong though, but that's my best guess...
Old 02-23-2006, 07:00 PM
  #467
2002yroneformula's Avatar
Don't remember seeing another pic so I'm gonna guess that at least one could possibly be to kill power, instead of having a Push/Pull type disconnect
Old 02-23-2006, 07:08 PM
  #468
boostedinaz's Avatar
Nope he is correct. The kill switch/button has to be clearly visable as to how to turn the car off.
Old 02-23-2006, 07:46 PM
  #469
B18B1LS1's Avatar
Some are used for a burn-out revlimiter too.
Jeffrey
Old 02-23-2006, 09:58 PM
  #470
427
427's Avatar
One is for the data record function of the BS3 and the other arms the air on the chutes.
Kurt
Old 02-23-2006, 11:35 PM
  #471
Wnts2Go10O's Avatar
so over the past few months conversations went like this:
W2W: hey, its {enter whoever called here} were gonna order this, this, and this...and probably a few of that.
Dave: mmkay, i write the check tonite.
awesome car man. always cool to someones dreams come to fruition. we need pictures of your face when u pick it up. kid ina damn candy store, youll be.
Old 02-24-2006, 06:21 AM
  #472
2001WS6Vert's Avatar
So how many man hours have we got into this? Will this car have a shot at the Riddler award? Can I buy a front row ticket to see it at the show? I'll bet it'll have a constant swarm of bees (car nuts) around it.
Old 02-24-2006, 07:22 AM
  #473
Z06PSI's Avatar
Is that as far as the downpipe is going to run?
Old 02-24-2006, 08:13 AM
  #474
WAHUSKER's Avatar
DAMN Dave!!! After looking at these pics I need to go have a smoke.....SWEET!
Then I think I'll go drive my POS into a tree.
So what's the goal, hanging with John Force, or beating Steve's 69 in a car show?
  #475
7 Second Club
10.5 Dave's Avatar
I don't think I have a chance at the Riddler.IIRC the car that won it last year had over a million dollars put into it.
Ronnie Dukes convertible was more tricked out than my car and he didn't win either.
Old 02-24-2006, 11:00 AM
  #476
Louis's Avatar
The nature of a drysump is vacuum and oil control. Depending on the width of the stages and a few other details determines the vacuum that the system runs at.
So yes, the 3/4th stages could be used for vacuum, but any scavenge stage is going to add to the vac that is already created
Old 02-24-2006, 12:01 PM
  #477
Adrenaline_Z's Avatar
Nothing to say that hasn't already been said about the workmanship and beauty
of this project.
I'm awaiting a video and more photos of the completed car!
P.S. This thread would be half the length if we stopped quoting every pic
and full initial story!
Old 02-24-2006, 01:23 PM
  #478
LS1TECH Sponsor
Kevin@W2W's Avatar
Happy Friday boys.
Nothing really special today. Our guys have been kind of slacking a little so all I have is this valve cover pic.
Am I?
Just kidding?
Maybe?
Have a good weekend guys and check out Dave's ride in the sun!!!!
Old 02-24-2006, 01:32 PM
  #479
Birdie2000's Avatar
Damn that looks good!
So, did it get out there under its own power?
Old 02-24-2006, 01:39 PM
  #480
JRcamaroZ28's Avatar
damn that looks real good..i know my vote for next years LS1Tech calendar cover photo
JR
Quick Reply: Roofer Dave's car back from paint (56K warning)
