402 + P-1SC @ 6 psi Dyno results
Old 02-11-2006, 10:59 AM
WAHUSKER's Avatar
Default 402 + P-1SC @ 6 psi Dyno results
Well, the short story is I hit my goal. 506.5 rwhp & 498.8 rwtq SAE!
The long story is on the 1st pass it was a little lean, and was at 510 rwhp & 516 rwtq. So we started richening things up at high rpms, leaning them out down low, and made it stay in 3rd gear. The 1st pass only lasted about 3 seconds.
We made 5-6 pulls, so it was pretty close when we got there. But it definitely runs out of fuel pump above ~ 5500 rpm. No matter what we did, the inj duty cycle rose & the a/f started to lean out. Nothing dangerous, I can make a pass or 2 at the track with it this way. But I will need to install a Racetronix, my 3.40 gears, and some better tires before I can get serious.
Bottom line I gained 121 rwhp & 95 rwtq @ 6 psi over the storker, 145 hp & 135 tq over the old motor. Oh, and at the motor it works out to 690 hp & 680 tq now with the 27% driveline loss I have. (or roughly + 200 in both categories) YEAH BABY!!!
But I may need to go with a smaller s/c pulley to run the 10.90 I'm aiming for. I figure this setup is good for low 11s. My impeller speed is only 52k now, so I can swap out my 3.85 for a 3.6 or 3.4.
Here is the dyno graph & the HP Tuner log chart....
File Type: doc
Old 02-11-2006, 11:06 AM
kp
kp's Avatar
Not bad, next time lock the converter and you will pick up ~30rwhp, can tell by the graph it isnt locked. You should be able to get in the 10s with that power even with an iron block if you can get the car to 60 foot well.
Old 02-11-2006, 05:09 PM
Calbo's Avatar
I have been thinking of using my p1 on a 408 and have gotten different opinions. Procharger told me on friday it would not get me the 500/500 I am looking for. Way to go! It can be done.
Old 02-11-2006, 09:54 PM
WAHUSKER's Avatar
I think you can get more if you set it up right. Certainly a D series would have better results on a big cube motor, but with a good cam & heads, an 8 rib belt, etc etc should be doable.....
Old 02-11-2006, 09:58 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,163 Likes on 756 Posts
I went 11.0@123mph NA with 471rwhp, 4500 stall, and 4.10 gears, You could hit 10's if you can hook it.
Old 02-12-2006, 12:55 AM
xLBx's Avatar
I am building up a 402ci with AFR Heads & large Single Turbo. What would be the best cam to hold peak power @ 6500rpm ?
Old 02-12-2006, 02:06 AM
andereck's Avatar
Really? Are you sure about that? ATI does that on stock engines routinely.
Old 02-12-2006, 10:08 AM
Drewstein's Avatar
Great numbers, now time to turn up the boost!
Old 02-12-2006, 10:12 AM
EPP
EPP's Avatar
What fuel pump and injectors are you using? Bob
Old 02-12-2006, 03:27 PM
Calbo's Avatar
The fellow I spoke with told me I would have to really push the P1 to get 500. Explained to him I ony wanted 4-6# (for longevity reasons) and he said I wouldn't get the 500/500 I was looking for. Told me to upgrade to a D1. This would be in a truck, not a six speed.
Old 02-12-2006, 05:14 PM
andereck's Avatar
Well I'm sorry about that, the information isn't really accurate. The D1SC would have been recommended for larger displacement to allow for future growth, but the P1SC would get it done.
Old 02-12-2006, 09:07 PM
WAHUSKER's Avatar
I ran an 11.07 @ 125 my frist trip to the track. Not too shabby for a 4,000 lb car! Now to get a Ractronix pump & some stickier tires. And maybe a smaller pulley to make sure.
And I have Motron 60s with the ATI 240L/hr pump Bob, with the Aeromotive 1000 regulator.
