Building a Block thats turbo friendly, help
Old Feb 16, 2006 | 03:41 PM
JD_Z28's Avatar
Default Building a Block thats turbo friendly, help
The plan is to build a new block because i recently cracked a piston on my
02 Z28. I want to buy an already assembled 347 short block that is setup for my STS Turbo kit. Im new to this so im not sure what I exactly need. Im thinking lq9 heads and a Z06 cam. What else will I need to build a strong motor, I want to do this just once so I could use advice on what I need and a shop I can get a good price for a Block thats assembled. Also what commpression should I have it set for. Any help is greatly appreciated, thanks.
Old Feb 16, 2006 | 03:47 PM
ddnspider's Avatar
well if youre already getting the shortblock assembled and you have a choice of heads and cam,besides valvetrain theres not much else.If you wanted to know what specifically in a shortblock to get id do a stock crank,Callies rods and eithe Diamond or Weiseco dished pistons
Old Feb 16, 2006 | 04:41 PM
bboyferal's Avatar
How'd you crack it if I may ask.
Old Feb 16, 2006 | 04:48 PM
JD_Z28's Avatar
I only ran 5 1/2 lbs of boost. My buddy tuned it for me without a wideband and he thought he riched it out plentty, but obviously didn't, cracked cyliner 7
Old Feb 16, 2006 | 04:50 PM
trtturbo's Avatar
John, I will be getting with you in the a.m.
Sent you an email.
Old Feb 16, 2006 | 05:39 PM
mdhmi's Avatar
The Z06 cam is fine. I wouldn't limit yourself by going with a large CC head.
Mark
Old Feb 16, 2006 | 06:15 PM
98turbls1's Avatar
I'm also in the market too...I'm going with a 6.0 block though...I'm shooting for 850rwhp and want to drive it often...
Old Feb 16, 2006 | 09:02 PM
FastKat's Avatar
How much money are you trying to spend, and what are your performance goals? Are you looking for forged rods and pistons, or are you trying to use a stock internal shortblock and get the compression down the a set of heads?
Old Feb 16, 2006 | 09:25 PM
buldogg's Avatar
I second the Z06 but if you want the most out of your setup look into the MTI Stealth II cam or the Lingenfelther GT7 both will give you a little more than the Z06. I actually bought both cams and I like the GT7 the best. I also went with LQ9 heads, my compression is around 8.7, let me know if I can answer any questions for you I just rebuilt mine about a month ago and did more research then I really wanted to.
