Finished!!!! Pics
Old Feb 24, 2006 | 04:31 PM
Scalpel's Avatar
As long as you roll into the gas and don't punch it or do the ole' banging the throttle off of the 2-step deal, the rear will last a good while. I have pushed 500+ RWHP through my 10 bolt for >11,000 miles w/out issues.
Old Feb 24, 2006 | 05:09 PM
KAOS's Avatar
never thought it was goin to happen. what a friend, lol. whats the fun of a 2 step if you cant use it!! gotta get that brother of yours to tune it up. then its time to get at it
Old Feb 24, 2006 | 05:19 PM
2001WS6Vert's Avatar
The flex pipe has gotta go.
Old Feb 24, 2006 | 05:36 PM
Scalpel's Avatar
Daniel, what is that flex pipe coming off of? Or where is it supposed to connect?
Old Feb 24, 2006 | 06:24 PM
kenm240's Avatar
Open dump for the wastegate I would imagine...I'll bet it sounds crazy when that thing opens up.
Old Feb 24, 2006 | 06:25 PM
Scalpel's Avatar
Does it even need a dump, or can it just go to atmosphere?
Old Feb 24, 2006 | 06:33 PM
Scalpel's Avatar
PS, this has the truck mani's on it now, right?
Old Feb 24, 2006 | 07:01 PM
fletchls1's Avatar
very nice setup. Just curious how you made all of that room where your turbo is?
Old Feb 24, 2006 | 07:24 PM
Cbrakllr's Avatar
Smile
That is sooo sick man. Good work, looks great.
Old Feb 24, 2006 | 07:32 PM
frcefed98's Avatar
There is tons of room right there, just move the fans and you can place a good sized turbo there.
J
Old Feb 24, 2006 | 08:15 PM
RealQuick's Avatar
Awesome! Congrats!
Old Feb 24, 2006 | 08:28 PM
  #32
half-n-half's Avatar
looks awesome....i love th setup and how the DP is runnig...i think i wll mimic my dp off of that one...which brings me to a question...you mention a 4" cutout, is that a 4 inch dp going through there?
Congrats on the setup; seriously looks awesome!
Louie
Old Feb 24, 2006 | 10:50 PM
  #33
Frost's Avatar
Man I'm glad to see that J.P. got you your kit and that it fit well. I know what the excitement level is, I'm there too.
Good luck dude.
Old Feb 25, 2006 | 06:53 AM
  #34
KAOS's Avatar
well you can set the rad up about 3 inches with out doing any mods at all, besides fabbing up new brackets. and i cant believe you guys dont like my flex pipe. all it does is just route the waste where i want it to go. it really doesnt look that bad. yes levi its coming off of the wg, just a directinoal thing. if they made those things out of stainless think how easy it would be to fab up a kit, lol. but its good to hear what people say. yes this is the truck manifold kit and its just a 3 inch down pipe. and the cutout may be a 3.5 im not too sure. any body want to guess numbers and 1/4 mile times? be fun to see who is the closest
  #35
KAOS's Avatar
any body want to throw me a line on wiring up that fan? i mentioned it i an earlier post, is that how you do it
Old Feb 25, 2006 | 07:47 AM
  #36
Scalpel's Avatar
The fan should only have two wires, power and ground. Most likely they're interchangeable. If both fans have the same two wire colors, hook the two same colored ones to power, the other two colors to ground. You should have a switch inline of the two going to power so that they're not on 24/7.
Old Feb 25, 2006 | 07:50 AM
  #37
Scalpel's Avatar
You could also take the + from one fan and run it to your power, the - from that fan could be connected to the + of your other fan, the - of that fan could then go to ground. Put a switch inline of the wire going to the power source.
Old Feb 25, 2006 | 10:53 AM
  #38
LTLHOMER's Avatar
If one craps out, you would lose both fans. Wire them in parallel.
I also think you'd wind up having 12 volts split between the two fans instead of sending a full 12-volts to each fan.
Old Feb 25, 2006 | 12:43 PM
  #39
KAOS's Avatar
i thought you could wire them into your stock harness and that way you can controll when they came on. i thought you wired them in a series i order to make it work that way. and yes the fan just has 2 wires. i really didnt want another switch to worry about.
Old Feb 25, 2006 | 12:59 PM
  #40
GrahamHill's Avatar
They would be 6V like that right?
