View Poll Results: which setup should i go with.
408 + bottle
9
13.64%
427,solid roller, Ls7 heads
12
18.18%
408, low compression, Ysi vortech blower.
45
68.18%
Voters: 66. You may not vote on this poll
Which setup for my z06.
Old Jun 1, 2006 | 07:15 PM
eviltwins's Avatar
Originally Posted by Camaro_Zach
comming from a twin turbo vette owner...if youre not HARDCORE dont do it, its so tight. do the blower if youre content with sub 600 rwhp. honestly. tti kit, great...but damn its tight, its a pain to do anything...except for plug and oil changes, those are still ok hahaha.
http://forums.corvetteforum.com/show....php?t=1381425
735 RWHP on a stock headed 346 on pump gas + meth = do a blower if you're content with under 600 RWHP? How about their vert going 9's @ 150 on their blower?
Old Jun 4, 2006 | 10:04 AM
2MuchRiceMakesMeSick's Avatar
I would go with the low compression and twin turbos (or blower)
Old Jun 4, 2006 | 03:58 PM
M6HuggerSS's Avatar
im voting for a low comp. 408 and an A&A kit.
with a well built bottom end, and meth, you could see 800+rwhp
good luck, let us know what you choose.
Old Jun 5, 2006 | 10:43 PM
Camaro_Zach's Avatar
ok dude relax, i didnt say no blower ever will surpass 600 rwhp and that turbos are god. im saying any shelf kit will have issues surpassing that on pump gas WITHOUT meth, AND there are more belt issues with blowers than anything else. honestly i never once said blowers cant surpass 600 rwhp, i was generalizing what most blower packages do. this paxton kit is new to the ls1 market. once again relax. mr . you can roll em till they fall outta your head.
OH AND not to mention thats a 20g setup as he states in the thread, im comparing a 7g turbo kit to a 6-7g blower setup.
Old Jun 12, 2006 | 05:09 PM
jic's Avatar
jic
vortech blower
Old Jun 12, 2006 | 08:39 PM
allngn_c5's Avatar
I like the low compression 408 option ysi. That is exactly what I am going to be doing in a couple years. Or sooner if someone wants to buy my current motor, or I make a lot of money with O.T. in a short time like I did to finance the current setup.
My car is already set for the next engine. All mods listed in sig. Good luck. Just a side note, if money is no option, go 427 TT !!!!!
Old Sep 30, 2006 | 02:21 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Go with the blower.
Old Oct 1, 2006 | 02:14 AM
BOONE's Avatar
408 and turbine or turbines of choice.
Old Oct 1, 2006 | 09:45 AM
chriswtx's Avatar
im voting for a low comp. 408 and an STS twin turbos. Here's a 402 STS at 15psi on a hot day and 12psi on a cool day...
Old Oct 1, 2006 | 12:40 PM
eviltwins's Avatar
Why does everyone get so uptight over it being on a hot or cool day? The dyno has correction algorithms for temperature and pressure, and the corrected peak numbers will be very similar between a hot and cold day.
Old Oct 1, 2006 | 01:42 PM
02Vortech's Avatar
427 TURBO !#!#%$@#$^#^#^@T$^@%
or blower if i have 2 pick from your list
Old Oct 1, 2006 | 03:10 PM
  #32
chriswtx's Avatar
Even with the correction factor, a boosted car will make more power on a cooler day. The correction factor is ok for a NA car....
Old Oct 1, 2006 | 04:41 PM
  #33
eviltwins's Avatar
It's not like on a hotter day the turbos put any more heat into the airstream, it's all a percentage and the correction factor for temperature I have found to be very accurate. Barometric pressure and altitude is another thing, but if you dyno at the same place on a 60 and a 90 degree day SAE corrected they are going to come out to very similar numbers. I've been messing around with turbo cars for over 15 years, and this has always been the case with dynojets.
Old Oct 2, 2006 | 01:02 PM
  #34
VINCE's Avatar
Shorty Director
I would stick with the nitrous and get a non exploding clutch
